kawasakijockey
posted December 18, 2010 05:46 PM
Tried out the 15/45 today
Same ratio as 16/48. Got to get more adjusted to it but it did ok for me. 1.41, 1.42 60fts and 9.03, 9.04 ets @ 149 was the best I could do for now. I need to adjust the shock for the gear change and find the right throttle roll speed and it will drop the 60 a bit and the et. I was sure hoping for that 8 today. I think the da was around -7 feet too. Weighed the bike with me on it on the track scale with very little fuel and the Adams arm and Hook up tire and saw 750lbs. That is 15 lbs different than the last two weighs with the stock arm and extensions, 3gal of fuel, and Usoft.
Anyway, I believe the 8 is just about to happen.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
kaw-rick
posted December 18, 2010 06:13 PM
nice
Wheelie
Old Man
posted December 18, 2010 06:25 PM
quote: Same ratio as 16/48. Got to get more adjusted to it but it did ok for me. 1.41, 1.42 60fts and 9.03, 9.04 ets @ 149 was the best I could do for now. I need to adjust the shock for the gear change and find the right throttle roll speed and it will drop the 60 a bit and the et. I was sure hoping for that 8 today. I think the da was around -7 feet too. Weighed the bike with me on it on the track scale with very little fuel and the Adams arm and Hook up tire and saw 750lbs. That is 15 lbs different than the last two weighs with the stock arm and extensions, 3gal of fuel, and Usoft.
James did you wheelie in 1st gear at all?
wee
posted December 18, 2010 06:28 PM
Why would you run the small front sprocket anyway instead of 16/48? That can't be good on the chain.
kawasakijockey
posted December 18, 2010 06:34 PM
wee
Ohhh yeah! 3 times I was so high up I saw Jesus. This is where that throttle roll speed comes in, I'm rolling too quick in the first 15-20ft I think. Cant slam it wide open like before it seems. Overall, it seems a lot easier to ride than I was anticipating. My first pass was a gentle 9.30 lol.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Wheelie
Old Man
posted December 18, 2010 06:36 PM
to aggressive with that clutch amigo. you are at 12 over correct?
wee
kawasakijockey
posted December 18, 2010 06:41 PM
quote: Why would you run the small front sprocket anyway instead of 16/48? That can't be good on the chain.
Lots of the liter bikes have the small sprocket with 530 chain and they do fine. My 954 has 8500 track miles on the 15t and that 530 chain has 14k miles total.
I wouldnt run the 15t on a stock arm though.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
kawasakijockey
posted December 18, 2010 06:42 PM
quote: to aggressive with that clutch amigo. you are at 12 over correct?
wee
No way Jose, 68 in wb (10 in over).
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Wheelie
Old Man
posted December 18, 2010 06:50 PM
wee
there's yer 8 second problamo. hehe
wee
kawasakijockey
posted December 18, 2010 06:55 PM
I will get it though....like the "stock" busa there today running 8.82 with only a 5.81 eighth mile..200lb rider.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Wheelie
Old Man
posted December 18, 2010 06:59 PM
quote: I will get it though....like the "stock" busa there today running 8.82 with only a 5.81 eighth mile..200lb rider.
you sure that wasn't a stock v max? you gonna be at mlk race next month, you and the Bad Guy can pick on meeee.
wee
kawasakijockey
posted December 18, 2010 07:01 PM
He says if I go he will go, so I am gonna be thinking about it. I have not been to HMP before.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
1badzx12r
posted December 18, 2010 07:10 PM
Edited By: 1badzx12r on 19 Dec 2010 03:12
quote: He says if I go he will go, so I am gonna be thinking about it. I have not been to HMP before.
lets go and kick his ass . between the 2 of us wee is doomed .. wee and lucky run me and you best 3 out of 5 ..
Wheelie
Old Man
posted December 18, 2010 07:18 PM
get a lane Chico!
wee
1badzx12r
posted December 18, 2010 07:29 PM
Edited By: 1badzx12r on 19 Dec 2010 03:30
get a lane Chico!
wee
ok Chavalita
Wheelie
Old Man
posted December 18, 2010 07:35 PM
get a lane Chico!
wee
ok Chavalita
sorry to jack your thread KJockey, btw good pass.
wee
kawasakijockey
posted December 18, 2010 07:37 PM
LOL, it's all good Wee..
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Lucky14
posted December 18, 2010 07:42 PM
quote: ................... wee and lucky run me and you best 3 out of 5 ..
4 at a time down the track?
Never done that.............
Sounds like fun!
Wheelie
Old Man
posted December 18, 2010 07:44 PM
Sounds like fun!
I have, at Yello Belly and Green Valley
wee
kawasakijockey
posted December 18, 2010 07:47 PM
Sounds like fun!
wee
Whatttt???????
2007 ZX-14
1.38 60ft
9.03 @ 149mph
1badzx12r
posted December 18, 2010 08:49 PM
Sounds like fun!
http://www.bing.com/videos/watch/video/4-jet-car-drag-race/a5d27ac3f9b09e9fe3e0a5d27ac3f9b09e9fe3e0-280730010565?q=4+lane+drag+racing&FORM=VIRE3
06redzx14
posted December 18, 2010 09:09 PM
Good job James
