BIKELAND > FORUMS > ZX-14.com > Thread: BLEW my motor last night NEW TOPIC NEW POLL POST REPLY
08green
posted December 06, 2010 02:40 PM        Edited By: 08green on 7 Dec 2010 02:23
It was bound to happen, but im still abit baffled as to why.... Let me run down the engine mods:
Web cams, jims stg 1 head, HD valve springs,put together by a great engine builder whom shall remain nameless cause i dont want to drag his name thu the mud.
Basically the engine was built last summer with light weight wheels and ran fairly strong. Like 125-128 in the 1/8 on pump gas in TX . I weigh 170unsuited. Basically i ran the bike in the 1/8 mile a few months ago and it was slow as shit like 119mph and barely a 6.01..WTF.
Then last night after a fresh oil change and fresh MRX01, at the track i get teched-in and check my oil level only to notice my oil glass was "milky" Hmmmm.. i thought head gasket could be blown,,, made a pass(which i shouldnt have) bitch went 6.3@111mph and was knocking on the return road...cut off engine. Drained oil this morning.Oil had no shavings and looked good.
Several people say it is prolly a valve keeper popped out, but my question is why would a blown head gasket pop a keeper? Thoughts?
2004 ZX10
2008 ZX14
posted December 06, 2010 02:54 PM        Edited By: smokinZX14 on 6 Dec 2010 22:57
Well the milky oil could just be do to the cold temps and not completely warming up the motor .. Mine does that this time of year .. Chad had the same problem last year .. ZX14 just don't have head gasket problems ... If you spit a shim your HP will be down as well as a ticking sound or rapping sound ... I have seen more than a few spit shims ... First pull the Valve cover and have a look see .. If a shim is out just pop it back in a you are good to go ... Drain the oil ( HOT ) and replace with fresh oil ... It will take some riding to remove or burn off the water in the oil ... You have to ride these bikes to full warm up this time of the year or this will happen again ..
LeonidasZX14
posted December 06, 2010 03:08 PM
X2 I was worried as hell about the white stuff. Put it in direct sun with the oil cap off after you have ran it for a while and it should clear up.
09' ZX14
posted December 06, 2010 03:41 PM
Mine was milky yesterday at the track. After a few passes I took a look and it was gone.
If you had water in the oil you would have seen it when you drained it.
08green
posted December 06, 2010 03:54 PM        Edited By: 08green on 6 Dec 2010 23:57
Its funny cause this morning when i pulled the oil, no white stuff....(motor was warmed up , but rather hard to start too) But i wonder why the knocking with HD valve springs/ jims zx12 cam chain mod too and no other signs....i had the 0 weight brock oil(alisyn)..
When the bike slowed down a few months ago there was no knocking sound..it was just slow, but hot too that day on pump gas..
2004 ZX10
2008 ZX14
posted December 06, 2010 04:00 PM        Edited By: smokinZX14 on 7 Dec 2010 00:02
When the bike slowed down a few months ago there was no knocking sound..it was just slow, but hot too on pump gas..
If the shim get wedged sideways you will lose power on one hole and make NO sound .. So you are running on 3 holes and not all four ...If you kept riding that way the shim may have popped all the way out making the ticking or rapping sound you are hearing now.. Pull the Valve cover and take a look .. Stop guessing .. If you have heavy springs with your cams you might what to give Jim a call and ask him what up ...
posted December 06, 2010 04:04 PM
What springs and retainers are you using? Did you hold it on the limiter??
08green
posted December 06, 2010 04:22 PM
Oh valve cover will get pulled within a few weeks..Glad i got a zx10 as a backup toy and it runs damn good...I dont know what springs or retainers(whatever jim uses)..i guess i shoulda asked for a complete parts list when i shelled out 3k for this head and labor combo...
2004 ZX10
2008 ZX14
posted December 06, 2010 04:23 PM
Jim probably provided an invoice to the builder. Ask him.
08green
posted December 06, 2010 04:26 PM
I think ima visit the kawasaki parts store and familarize myself with what exactly is a keeper or a shim cause i dont have the slightest idea..
2004 ZX10
2008 ZX14
08green
posted December 06, 2010 04:45 PM
Is a keeper also known as a collet? youtube engine building videos are awesome!!
2004 ZX10
2008 ZX14
RICH CRAFT 1
posted December 06, 2010 04:50 PM
If you have heavy duty valve springs it's not likely you spit a shim. Most of the time that comes from floating the valve. And that's hard to do with heavy springs. I would do a leak down the motor. If you don't have that equipment? do a compression check. It should have between 190 and 220 psi. Take all the spark plugs out and spend the motor with the throttle wide open, but if that knocking was coming from the bottom in I would pull the oil pan and look at the rods. If it has a spun rod bearing it's easy to spot they usually turn black around the bottom of the rod. If you grab hold of the bottom of the rod and shake it it usually has more slack. Most 14th knockout # two and # three rod bearing. Most people believe it's because of the oil pressure and that could be? but I know in my case it was detonation. The number one killer to the number three rod bearing. Cylinders two and three run hotter because they're inside. But in my case it was because the nitrous was to lean, and not pulling enough timing out. After I fixed these problems I had no more rod bearing problems. I hope this helps. Ken
Red 06 ZX14 RR
posted December 06, 2010 04:51 PM
Yes.
posted December 06, 2010 05:18 PM
If he has HD springs and they are set up correctly .. If he pull lock though a retainer... Lot of ifs ... That why i said pull the valve cover first and take a look .. If all is good on top pull the pan .. Rule one : always go the last place that was worked on .. In this case the head ..
posted December 06, 2010 05:24 PM        Edited By: smokinZX14 on 7 Dec 2010 01:26
And if you did spin a bearing ......It's time for a stroker motor !!!
SteddyTeddy
posted December 06, 2010 05:57 PM
I'm thinking spun bearing.
osti33
posted December 06, 2010 06:23 PM
+1
I would drop the pan and have a look.
posted December 06, 2010 06:45 PM
5 bucks it's not a rod .. Remember last time the motor was touched was for head work .. He said he drained the oil and no gold or silver flakes ..MPH dropped from 126 to 119 Hummmmm sounds like it running on 3 holes and not 4 ..
08green
posted December 06, 2010 07:04 PM
ooo wee i hope its not...can the valve cover be taken off without the motor being dropped? Again; oil looks just as new as when i put it in a week ago..
2004 ZX10
2008 ZX14
posted December 06, 2010 07:10 PM
You don't have to drop the motor to remove the valve cover..
1badzx12r
posted December 06, 2010 07:31 PM
5 bucks it's not a rod . Hummmmm sounds like it running on 3 holes and not 4 ..
ain't no rod
osr
posted December 06, 2010 08:16 PM
i'm betting a shim on the exhaust side -- we have spit them with kibblewhite springs and APE springs -- so far we've been lucky and not hurt anything.
Y2KZX12R
CompetitionCNC.com
posted December 07, 2010 04:48 AM
08green, give me a call I'll walk you threw a procedure to find out what it is.
Competition CNC 860-274-0631
Y2KZX12R
CompetitionCNC.com
Bently
2012 14r In Blue and no Mods!
posted December 07, 2010 06:51 AM
There you go can't beat that!
posted December 07, 2010 07:04 AM
Like i said call Jim .. Jim is a nice guy and doesn't bite ..
All times are America/Va [ This thread is 4 pages long: 1  2  3  4     Next» ] < Previous Thread     Next Thread >
0.24892497062683 seconds processing time
