BIKELAND > FORUMS > ZX-14.com > Thread: anybody know the walbro part number NEW TOPIC NEW POLL POST REPLY
06redzx14
posted December 06, 2010 08:16 AM
does anybody know the walbro fuel pump part number that will fit intank on a 14?
06redzx14
posted December 07, 2010 12:42 PM
Quote from: PetriK on August 21, 2008, 10:30:10 AM
Got the Walbro GSS342 - that is a bit long (5mm) for Busa - can fit it though. But GSS342 fits perfectly to ZX-14
LeonidasZX14
posted December 07, 2010 04:10 PM
Good info Thanks
09' ZX14
kingtramp
posted December 07, 2010 11:35 PM        Edited By: kingtramp on 8 Dec 2010 07:36
chad get one ,kick to fuel pressure to 60 psi and spray baby ,,baby spray
06redzx14
posted December 15, 2010 07:01 PM
Walbro in housing stock pump to the left
06redzx14
posted December 16, 2010 07:04 PM
Be sure to order the wire connector with the pump I'm on hold til mine arrive. My regulator is setup for 55 psi currently, but I'll be pushing towards 70. Thanks for posting the pic gilbertj
gilberjj
Friend of Fast
posted December 16, 2010 08:57 PM
Great thread, just ordered mine!!
06redzx14
posted December 23, 2010 11:47 AM
Finally finished
06redzx14
posted December 23, 2010 04:22 PM
If you decide to do this mode be sure to keep all the wires in tight. If anything is outside of the plastic housing it will not want to go in
Stu64
posted December 23, 2010 06:00 PM        Edited By: Stu64 on 24 Dec 2010 02:02
Just so you know the 08 and newer pumps will need to be modified, not just drop in like the 06-07 pump above.
Big_T112
posted December 23, 2010 07:36 PM
th 08 and newer don't have the sump right?
Compton
posted December 24, 2010 06:52 AM
correct.
b.w.
06redzx14
posted May 09, 2011 07:40 PM
quick update.
I've been fighting some fueling issues lately with the original pump I installed. Could have been caused by the Q16 I left in the tank for 3 months, but i'm not sure. With the new pump I just installed I shaved the green piece attached to the filter bag about 2-3 mm. The fit improved alot. I think I will add a +12 relay to this pump also.
gilberjj
Friend of Fast
posted May 10, 2011 11:44 AM
My GSS342 fit like stock in my 06 housing. Great mod!
1badzx12r
posted May 10, 2011 12:38 PM        Edited By: 1badzx12r on 10 May 2011 20:55
quick update.
i think i may be a little of an expert on these pumps from all the failures from it .. i ran 95psi tho on boost .. some things to look at ..check all the o-rings and seals on the pump that push into the housing .. 2nd check the 3 welch plugs on the top of the pump and see if none have pop out .. 3rd and most important get rid of it and go with an external pump .. i've got so much fuel now i can run 2 turbo zx14's thru my new external pump there other pumps but this is the pump i'm using http://cgi.ebay.com/ebaymotors/New-Kinsler-Bosch-Electric-Fuel-Injection-EFI-Pump-/180621151188?pt=Race_Car_Parts&hash=item2a0ddc0bd4
Dale
posted May 10, 2011 07:36 PM
Good Advice on going with external pump!
2007 Kawasaki Ninja ZX-14 Special Edition Turbocharged
0.3911030292511 seconds processing time
