BIKELAND > FORUMS > ZX-14.com > Thread: Dry Nitrous 101 NEW TOPIC NEW POLL POST REPLY
3000psi and falling
posted November 27, 2010 04:52 PM
Dry Nitrous 101
Ive been looking at a DynoTune Dry Nitrous system for my 14. It would be for very occasional use, comes with 15,30,40 hp jets. They claim you can install with no other mods?? Is there any truth to this? I thought you had to pull timing and add more fuel?
LeonidasZX14
posted November 27, 2010 04:55 PM
I have that kit and its a nice kit for the price. Very easy to install, but yes I would add fuel for sure.
09' ZX14
zxbob
posted November 27, 2010 07:04 PM
You can program your power commander to add fuel at full throttle ~ thats how I
installed it on my wifes bike !
Bob
3000psi and falling
posted November 27, 2010 10:33 PM
Will I even feel the 15 shot?
posted November 28, 2010 03:41 AM
Go with the 30
LeonidasZX14
posted November 28, 2010 04:53 AM
I imagine you would feel the 15 shot but I would go with the 30 shot. Smokin had great results with this setup as well.
09' ZX14
3000psi and falling
posted November 28, 2010 10:06 AM
30 and just add fuel with the pc? I dont need to pull timing?
LeonidasZX14
posted November 28, 2010 10:27 AM
No need to pull timing with a 30 shot. Run 93 and add 8% to 10% more fu
el just to be safe.
09' ZX14
kawasakijockey
posted November 28, 2010 10:30 AM
I would add 12% to a 30hp jet with 93.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
3000psi and falling
posted November 28, 2010 10:43 AM        Edited By: 3000psi and falling on 28 Nov 2010 18:44
How do you use the nitrous safely? Lets say im going down the highway at 50mph, I would shift into 2nd, then go to full throttle then hit the button? What do you do when its time to shift? Do you spray through a gear change or not? What happens if you bump rev limmiter on spray?
posted November 28, 2010 02:01 PM
If you bump the rev limited on spray it's not going to be good, especially if it spits a shim.
A good idea is guy a shift light (dyna shift minder is a good, easy light to use) and set it at 10,500 so that way you know when it's time to shift.
3000psi and falling
posted November 28, 2010 02:09 PM
ok, what is the right way to shift on spray? Do you just let off the spray then the throttle and shift as normal? Or spray through the shift?
kawasakijockey
posted November 28, 2010 02:10 PM
If you get the Power Commander Hub I can send you a wiring diagram to wire it as a window switch and auto change the fuel maps.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Big_T112
Or put a window switch to cut the spray off at a pre determined RPM. That's the safest.
01smokes
posted November 28, 2010 02:52 PM
+1 thats what i do, i use the nos mini progressive, it has a window switch built in and runs off the TPS so it pretty much does it all
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
0.22856712341309 seconds processing time
