BIKELAND > FORUMS > ZX-14.com > Thread: 06 14 dropped rod NEW TOPIC NEW POLL POST REPLY
FAST Z14
posted November 23, 2010 02:41 AM
06 14 dropped rod
Hi Guys just wanna know was there a problem with 06 - 14's dropping rod no 3 bearing?
FOLY HUCK
bbwatercool
posted November 23, 2010 08:32 AM
there is a oiling issue that we have found with all the ZX's..there are some case mods and crank mods that we do to help them oil better..give us a shout if you need help..
Cycle Concepts
1625 Lynwood Dr
Lancaster,SC 29720
803.285.8093
Home of the Drag Pak Clutch Pak!!
FAST Z14
posted November 24, 2010 04:07 AM
Thanks bbwatercool, we are in South Africa so thats not gonna help,anyway thanks for the reply will look up the oil mods
FOLY HUCK
posted November 24, 2010 06:32 AM
my 06 has been running strong over 4 years. i use motul 300v 15-50 (double ester synthetic)
wrongway
posted November 24, 2010 07:15 AM
maybe '06's don't have that problem.... I have been beating the hell out of mine and even with the stroker kit in there I have had no issues . I use rotella 15-40 and purolator filters.
bbwatercool
posted November 24, 2010 07:39 AM
I have had all years come into the shop with #3 rod shot..all from bone stock to highly modified..some guys are luck and others are not so lucky...
Cycle Concepts
1625 Lynwood Dr
Lancaster,SC 29720
803.285.8093
wrongway
posted November 24, 2010 08:05 AM
what kind of modification is it ? Do you need to split the cases to do it?
bbwatercool
posted November 24, 2010 02:00 PM
yes you have to split the engine cases to do it..the crankshaft gets modified for better oiling to the rod journals and the engine cases gets modified to be able to supply the oil where needed..
Cycle Concepts
1625 Lynwood Dr
Lancaster,SC 29720
803.285.8093
ninjaboy311
posted November 24, 2010 02:30 PM
I must have one of the special ones too....06 with well over 2000 passes...Amsoil and OEM filters, hot lap after hot lap and no issues.
Did see one just recently spin #3, but he kept the bike up on a wheelie too long and loss oil to the pickup. His fault.
kaw-rick
posted November 24, 2010 02:51 PM
I had the special edition 06 also .damn i miss that bike, it was a good1.
ninjaboy311
posted November 25, 2010 05:42 AM
I keep saying I'm going to upgrade my 14 to a new one. Well that was 2 years ago. I just can't justify buying a new one when my 06 is still running as good it does.
CraigChrist
BAWLS
posted November 25, 2010 06:17 PM
my 07 was the special no mechanical issues model as well.
60ft-------1.42
1/8th------5.97
mph-------119
0.22450613975525 seconds processing time
