BIKELAND > FORUMS > ZX-14.com > Thread: zx 14 cutting off in mid pass need help NEW TOPIC NEW POLL POST REPLY
nellics
posted November 22, 2010 10:35 AM
hey guys just wanted to run something by some fresh minds.
took the bike to the track yesterday, ran some decent passes but the bike looses power in the middle of my passes, gauge cluster will zero out like the bike just cuts off and clutch out and wheel speed will start it back up and continue on?????
sounds like a voltage issue to me but, just wondering what you guys think. bike has a mini controller, msd and a wideband along with an air shifter and shift light pulling on the factory charging system. battery is a busa fast by gast but has some age on it.
anyone encounter this problem please chime in open to all suggestions.
HITSQUAD
Flyboy
posted November 22, 2010 02:57 PM
I have encountered the same problem most recently at the Mojave Mile. Engine cuts out at WOT then comes back strong a couple seconds later.
Mine has been in the salts many times and I thought I might have a corroded line somewhere. Still haven't found the problem yet-- I was using Mr9 and Mr11 and thought a dirty fuel system might have caused the problem but I recently replaced the fuel filter and problem is still there-- Engine only cuts out at WOT-
"The World's Fastest Indian"
One fast red ZX-14,
posted November 22, 2010 03:10 PM        Edited By: smokinZX14 on 22 Nov 2010 23:11
Start with the MSD.. Start pulling off any of the goodies you added one at a time till it stops cutting out ..
kaw-rick
posted November 22, 2010 03:22 PM
kickstand?
nellics
posted November 22, 2010 05:34 PM
Thanks for the info guys, will let you know what the out come is.
HITSQUAD
kingtramp
posted November 22, 2010 09:59 PM        Edited By: kingtramp on 23 Nov 2010 06:00
Do you use an after market teather type safe kill switch, if so start the bike wingle the hell out of teather to see if bike is shutting down then back on.
TooHype
Go Hard or Go Home !!
posted November 23, 2010 08:26 PM
kickstand?
+1 . . A few af my buddies had that problem on their Busa and it did turned out to be a little switch or something near the kickstand.
Flyboy
posted November 23, 2010 09:46 PM
MSD?
Kill switch and kickstand seem like good places to start. Thanks---
One fast red ZX-14,
posted November 23, 2010 10:14 PM
MSD?
Yes he said he has MSD on his bike ..I know of two people that have had problems with their MSD.. I have no clue why you think you need an MSD on a zx14 but to each his own ..ZX14s just don't have these kind of problems till you start adding needless crap ..
Start with removing the mods you have made one at a time till it stops having problems .. That is pretty simple is it not ?
I have not heard of one single ZX14 with a kickstand switch problem , Busas yes , zx14s no ..
zx14fan
posted November 23, 2010 11:33 PM
smokin you crack me up.
06redzx14
posted November 24, 2010 06:14 AM
MSD makes the SB6
wrongway
posted November 24, 2010 06:55 AM
the gauges resetting sound like a voltage problem... bad news is that it could be anywhere from the battery to the ground. here is the electrical path to the gauges
17. Frame Ground 1
18. Water-proof Joint 1
19. Ignition Fuse 10 A (in Fuse Box 2)
20. ECU Fuse 15 A (in Fuse Box 2)
21. Ignition Switch
22. Main Fuse 30 A
23. Battery 12 V 14 Ah
24. Frame Ground 2
25. Engine Ground
I am guessing that the gauges loosing power did not kill the ignition , but the problem is affecting both the gauges and the ECU . check the components that are common to both
battery , grounds , ignition switch and fuse holders/wiring
Roy
0.35656905174255 seconds processing time
