BIKELAND > FORUMS > ZX-14.com > Thread: anyone using PCV shift kill ? NEW TOPIC NEW POLL POST REPLY
wrongway
posted November 21, 2010 04:27 PM
I see a download for a quickshift update on the powercommander site ... do I need to install that ?
thanks
Roy
wrongway
posted December 11, 2010 09:09 AM
I got the PCV shift kill working with an airshifter. After a few minutes worth of testing I found that the PCV killed the fuel when the circuit went open. So you cant just use the ground to the airshifter solenoid to trigger it. The PCV has screw down terminals for the shift kill so it is easy to wire up.
To make it work I used a relay that had both normally open and normally closed contacts ( 5 wire setup ) and used the airshifter signal to ground the relay and open the contacts. I just tested it out and it seemed to work ok on my test track.
I am really liking the PCV ...
built in shift kill , map per gear , 2 maps loaded for faster switchingand USB powered.
Roy
LeonidasZX14
posted December 12, 2010 05:59 AM
Disregard my PM
09' ZX14
0.214684009552 seconds processing time
