BIKELAND > FORUMS > ZX-14.com > Thread: 1/8 mile .HELP newb zx14 NEW TOPIC NEW POLL POST REPLY
bradkong12
posted November 10, 2010 08:37 AM
help on 1/8 mile times , 60feet times, 1.640s, 6.287 117mph, leaving at 8000rpm so shes not boggn , 45tooth was n between gear, faster with stock 41tooth, straped ,lowered, extenders ,shinko, rest stock, 08 special ed zx14 , weigh 150pounds . going 2 get exhaust and electrical when money good, BAZZAZ any good or POWER COM , BAZZAZ has QS , any suggestion would help, THK U, im newb
bradkong12
SteddyTeddy
posted November 10, 2010 08:41 AM
Seat time. Launch at a lower RPM and start working on getting your 60's down. Get the clutch out and work on getting the throttle open faster.
madnessracing
Vmax and Busa Beater
posted November 10, 2010 09:31 AM
Im -1 +1 and I weight about the same as you running low 1.40s high 1.30s sitting at 65!
Shorty's Performance
Team Madness Racing
TH1RT3EN
Trial And Error Control
posted November 10, 2010 10:00 AM        Edited By: TH1RT3EN on 10 Nov 2010 18:02
i have 115 lbs on you and i am getting close to your current times...
I dont know much but i would say lower your launch rpm by 500 for a few runs and see if you can improve that aspect. Also if your having the same issues i did/am having get the clutch out as quick as possible. It took me a little while to finally get to where i am at but i know i can do better.
Seat time is my best friend, i wish we could meet more often....
Only other thing i did which has helped me so far (ive only been able to practice on the back roads due to my local track closing for the season) Is the Rifleman Insert for the throttle. It makes the throttle 1/5 turn. Very easy to get to WOT. I also installed a wide open throttle switch and hooked it up to an LED on my dash just so i know when i am hitting WOT and where i am at on the track. Its just an idiot light for personal reference. But every little bit helps in my book....
Patrick
Quarter Pounder
with Cheese
posted November 10, 2010 04:31 PM
leaving at that rpm and those 60' times you are riding the clutch waaaaaaaaaaaaaay too long or not twisting the throttle.
video's will help you see what you are doing and what you can do to correct. Post them up here for help.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
bradkong12
posted November 11, 2010 10:45 AM
she jumps off at 8000rpm , carries front tire, need 2 chop seat , only videos i hav r from finish line , and n a computer that crashd, will tape start and post this spring, THKS guys
bradkong12
posted November 11, 2010 10:47 AM
Less launch rpm, more throttle.
bradkong12
posted November 11, 2010 10:53 AM
thks mans , yeah wish had vid so i could c which cluch or thr, hopn 2 hav exhaust and electrical when spring gets here, any suggestion on BAZZAZ or POWER CO ?? and what brand TRE
bradkong12
posted November 12, 2010 04:59 PM
I would stick with the Power Commander, as it has more maps available. I would skip the TRE and remove the secondary throttle plates. For an exhaust with great map support, you can't beat Brock's products.
bradkong12
posted November 14, 2010 12:07 PM
THKS Shane , just finishd readn 68pg thread, nice
bradkong12
posted November 14, 2010 03:56 PM
Glad you like the thread. Hopefully more good stuff to come, as I overhaul the bike this winter.
0.24284601211548 seconds processing time
