northernkaw
posted October 16, 2010 07:05 PM
dynojet hub firmware problems
went to the track first pass my autoshift through the hub worked. the next pass no shift. the hub worked the next day till it got hot, changed the hub same problem. called dynojet they told me they had a firmware up date for the pc3 to fix it. you need a 2.3.3 firmware. the 2.3.2 according to dynojet has probems that effect the functions of the hub turning on relays and solenoids. had the bike back out with no problems but I did not put the original pc3 back in the bike. check your firmware number and make sure its the 2.3.3. you can download it off their site.
