BIKELAND > FORUMS > ZX-14.com > Thread: Need a little help ... NEW TOPIC NEW POLL POST REPLY
posted October 14, 2010 09:09 AM
What size is the nut for the counter shaft on a zx14 ? I need to swap gears back to my 16 tooth ... I had a socket that fit it just fine but i lost it .. I had the damn thing in my hand 3 days ago ... I cleaned out my shop , moved everything and looked everywhere and that fucker is nowhere to be found ...
Thanks .....
dogg24
posted October 14, 2010 09:29 AM
I think it is a 1 and 1/16 six point socket.
2012 ZX14R SE, Streetmeg, PCV
posted October 14, 2010 09:39 AM
I have a 1 and 1/8 , 1 and 1/4 and those are two small .. The socket i had fit the very back part of the nut and not the smaller nut that is at the end of the nut ..
Jamesfs912
posted October 14, 2010 09:57 AM
it is a 1 1/16 inch socket..
LAB3
posted October 14, 2010 11:22 AM        Edited By: LAB3 on 14 Oct 2010 19:34
I think we used a 34 to 36MM I will look when I get back to the shop. A 1 1/16 is a 27MM
GREYHOUNDMOSES
posted October 14, 2010 11:46 AM
It is 27mm
It should be six sided and MUST be deep too clear the square cam.
kingtramp
posted October 14, 2010 12:30 PM
It is 27mm
X2
posted October 14, 2010 01:46 PM
Sears had the 1 1/6 6 point deep in stock .. I'll give that a try tonight ... I have been using the larger nut closest to the sprocket .. I have never tried to use the smaller one to remove the nut .. I wish i could find my socket that i have been using since 2005 , I think 1bad drove from Texas to FL and swiped it ..
gilberjj
Friend of Fast
posted October 14, 2010 02:00 PM
posted October 14, 2010 02:03 PM
Get a couple extra nuts...
posted October 14, 2010 02:09 PM
27mm positive of that. Orilleys was the only place that had it here
1badzx12r
posted October 14, 2010 02:18 PM        Edited By: 1badzx12r on 14 Oct 2010 22:23
umm no I've got my own 27mm and a 30mm for the clutch basket nut ..
now why you gonna use SAE on metric bolts .. even 1bad won't do that .
HINT the aliens took it
Superman T
posted October 16, 2010 10:20 AM
+1Sears have them but I remember it was a set. I would only use metric8
LAB3
posted October 16, 2010 05:03 PM
I found a old front sprocket nut. 27MM ( 1.067) the small hex, and the larger hex is 34.70 MM rough casting not machined hex drives on nut....................................
or 1.370 thousands of a inch. Odd size.. I use a hardened 1/2 drive 27MM deep socket.
0.40882802009583 seconds processing time
