BIKELAND > FORUMS > ZX-14.com > Thread: Lowering Foot pegs?...... NEW TOPIC NEW POLL POST REPLY
TH1RT3EN
Trial And Error Control
posted September 17, 2010 03:23 AM        Edited By: TH1RT3EN on 17 Sep 2010 11:47
I know many people have switched to the Buell foot pegs to give a bit of added clearance for them selves. But has anyone ever tried the "Cycle Pirates" 360 Degree foot pegs? I will be getting a set of them today for my b-day and going to install them. I am just curious on thoughts and any feed back if anyone else has used them. A local shop i go to often told me about them and that was the first time i had ever heard of the brand name. Supposedly with the 360 Degree aspect you can drop the pegs down about an inch maybe just a tad more, or any place you desire really... what do you think?
i frequently shop at indysuperbikes.com and that is where i found them.
pic below...
Patrick
BobC
posted September 17, 2010 05:32 AM
I think that you should consider footpegs that hinge upwards if you're going to lower them.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
TH1RT3EN
posted September 17, 2010 07:14 AM
These hinge the same way the stock pegs do. and they supposedly are able to re-use the factory tension spring to keep them down and in place.
Patrick
SLVR_BLT
Chicken Strips!
posted September 17, 2010 08:36 AM
How tall are you guys? Im the avg 5'10" but i think the stock pegs are too far low. Id actually thought of raising mine up with some aftermarket adjustable units. I been sort of hesitant because i really like the rubber isolated stockers which transmit no vibrations.
TH1RT3EN
posted September 17, 2010 09:01 AM
i am 6'4".. i have been thinking about lowering mine for a while just never got around to it..
and these pegs were a b-day present so that makes it even better to try out i think...
Patrick
SLVR_BLT
Chicken Strips!
posted September 17, 2010 09:06 AM
Patrick
OK now i see why, damn....you could play for the NBA lol! At my height the ZX is sized just perfectly.
Old Guy
posted September 17, 2010 09:40 PM        Edited By: Old Guy on 18 Sep 2010 05:44
For touring and commuting they are great. I have the Buells and 1 1/4" risers. Much better.
Dont worry about them getting in the way, I still had the lower pegs on this day
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
TH1RT3EN
posted September 18, 2010 05:27 AM
Ok well a bit of a review for these...
Install took roughly 30 minutes. Things were very easy. The new pegs are almost an inch & 1/2 lower and feel great.
The downfalls.....
I adjusted the brake lever and shifter levers to compensate for the lower peg position.
The problem is now my foot is roughly 1/2 an inch further away from the bike (the thickness of the little lowering block). Now I need the shifter peg and the brake peg to be 1/2 an inch longer as well. Since they are not; If I want to have the entire pad for the rear brake covered I have to ride pigeon toed. And that is very uncomfortable! Currently in a normal riding position only about a 1/4 of an inch is covered on the shifter peg and the rear brake pad.
I am currently looking into some adjustable brake and shifter levers to compensate this issue.
On a side note... How is this with the Buell pegs? Has anyone run into this issue before?
Patrick
epd345
posted September 18, 2010 05:41 AM
Silvbult, don't think that little strip of rubber makes a difference in vibration. I went from stock pegs to GP werkes pegs and now I use the Sato rearsets and I never noticed any difference in vibration from the stock pegs.
Quarter Pounder
with Cheese
posted September 18, 2010 05:42 AM
same issues with the buell pegs. I had the buells and hated them. Yanked off after 2 days. I bought a set of lowering pegs from Murphskits.com that go on a concours 14. They are much better and super comfortable. Direct swap in about 10 minutes.
Twistedthrottle.com has some pegs that seem to have a lot less outward offset than anything I have seen...just never seen in person before. Those come with option of different length of lowering.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
TH1RT3EN
posted September 18, 2010 07:05 AM        Edited By: TH1RT3EN on 18 Sep 2010 15:07
Thanks for the info Quarter Pounder.. im looking into a few different options..
Also last night i took off the lowering block and mounted the pegs in the stock location. I am going to be leaving them there until i figure out the loering aspect. As of right now i have noticed no difference in vibration feel coming from the pegs. I still feel minimal vibrations there. I am going on a longer ride today and i will update with the results...
Patrick
Quarter Pounder
with Cheese
posted September 18, 2010 07:14 AM
too bad you're so far away. Best test is in person.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
TH1RT3EN
posted September 18, 2010 07:22 AM
very true.... not many 14 riders around me that i get a chance to talk to...
Patrick
zx14fan
posted September 18, 2010 08:11 AM
Use the buell pegs those make your bike to wide.
Hellmutt
posted September 18, 2010 10:09 AM
I got the buell's on mine, only problem I had was the kickstand deploy was in the way -- but luckily, the member I bought them from here included a modded stand with that removed.
I like them ( after getting the controls adjusted just right ) for day to day street riding -- but for track days, I'd definitely swap back to the stockers and re-adjust the controls..........can't keep my feet in position all the time and it is a bit of an issue when I'm full lean and need to up/down shift or trailbrake
Old Guy
posted September 19, 2010 08:44 PM
I noticed that with the Buells too. That was a short session during a race day. If I was on my toes it was sketchy so rode flat footed and toe plates got mucho wear!
But I like them on the street and touring. Touch toes on the road too, but use that as a reminder to chill as I'm on the road......,hehehe.
On a XZ !!!!!
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
Hellmutt
posted September 20, 2010 06:05 AM
I'm usually always on the balls of my feet, but I wasn't at the track when I was trying these out -- I've got a nice little circuit of fresh asphalt mapped just outside of town here that allows me to "lightly" test-n-tune changes I make to suspension, gearing, controls, tires, etc. before I load up and drive all the way out to the track........scary stuff touching your toes to the ground when you're in a deep lean -- my cousin broke some toes when his foot caught and got dragged under the peg.........damn near ran over his own leg!
But of course, his dumbass was wearing sneakers instead of decent boots.
Those SBK adjustables look sweet though, and appear fairly easy to adjust compared to rearsets
Hellmutt
posted September 20, 2010 06:10 AM
Hey..........how'd you get on the track without taping up the lamps??
TH1RT3EN
posted October 10, 2010 04:51 PM        Edited By: TH1RT3EN on 11 Oct 2010 01:05
Master
If it ain't fast it aint me
posted October 11, 2010 03:01 PM
Cycle pirates are the best I love them and you can adjust them and get them to match you bike.
TH1RT3EN
posted October 11, 2010 07:46 PM
since i found the relocation brackets for the factory rear sets i will never suggest to anyone to buy the cycle pirates pegs. Big waste of money in my opinion, and too many mods needed to ride comfortably.
Patrick
LAB3
posted March 05, 2011 12:27 PM
We specialize in a wide range of products such as MOUNTAIN BIKES/ROAD BIKES, musical instruments,laptops, mobile
phones, plasma & lcd tv, mp3 & mp4 players, video games console,
digital cameras, dvd players (Etc) at cheap & affordable prices.
All our product comes with the minimum warranty of 1 year international
warranty from manufacturer.
Email Us At : UKemobileshopz@hotmail.com
SKYPE ID: EMOBILESHOPZ
Go AWAY. SPAM post. Does not belong here. You did this to my classified add .uncool.
blackbullet76
posted March 05, 2011 02:00 PM
I'm 6'1 and I got the Vortec rear sets on my 14. It lets you adjust everything. Might be a better setup for you.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
KJCulligan
posted May 03, 2011 12:14 AM
Murph's Peg Lowering Kit
Quarter Pounder -- Murph's peg lowering kit for Concours 14 was a simple bolt on substitute for the stock pegs on your ZX-14? Any mods needed for gear or brake levers? Thanks. KC
KJC
blaggie
Big14
posted May 05, 2011 10:39 AM
Take the rubbers off the stock pegs, grind or file down the raised peak at the outer edge of peg, locate some old bar grips, cut the grips to fit in the recess, epoxy glue in place and or, use two per peg allan head bolts through the original holes...
Hey presto, pegs are lowered by approximately 3/4" and for me are much more comfortable.
Easily returned to stock if you wish.....
Paully
0.25057792663574 seconds processing time
