BIKELAND > FORUMS > ZX-14.com > Thread: Stretching Questions.... NEW TOPIC NEW POLL POST REPLY
TH1RT3EN
Trial And Error Control
posted September 14, 2010 08:22 AM
Ok let me be the Moron who asks this question again.. (i have searched and i cant seem to find the answers i am looking for)
I am looking into stretching my 09. I would like to stretch it right around 4" maybe 5". I do go to the trak every now and then but it is mainly for pleasure street use. If i just add the extensions, chain, etc will i need to put lowering links on it to keep it stock height? I do not want to lower it any due to the stands i use. (pitbull front pin stand) The stand is a PITA to get set in currently and it would be impossible if i lower the front any. So how will the back of the bike sit if i extend it 4-5"?
I am also looking into switching to a Busa spring on the rear shock. I did it on my 07 and i would like to do it again on the 09.
Thanks for all the help..
Patrick
posted September 14, 2010 09:17 AM
If you extend it 4-5 inches it will raise the back a bit ..
madnessracing
Vmax and Busa Beater
posted September 14, 2010 09:39 AM
why do you wanna put a busa spring on your bike? how heavy are you?
Shorty's Performance
Team Madness Racing
TH1RT3EN
posted September 14, 2010 09:46 AM
I weigh in currently at 260. I am 6'4" also so lowering doesnt exactly feel right. I usually take decently long trips with the Girl Friend and she only weighs in at 130lbs.
So i am thinking a Busa spring will help out a bit. The 07 was never stretched though.
Patrick
NINJA12
posted September 14, 2010 12:48 PM
You don't need lowering links, but you will probably want them.
Like smokin said stretching will raise the rear of the bike.
Adjustable links will allow you to set the bike stance you want.
Quarter Pounder
with Cheese
posted September 14, 2010 01:50 PM
as far as using stands go...with extensions you will be forced to use a stand with paddles/flat pads that go under the swingarm. The spool locations are too far forward for a normal stand to work.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
1BadBusa
Zx14 killa
posted September 14, 2010 02:35 PM
I put an extra long tail on my bike to accommodate a large passenger. No problem carrying me 340lbs and my 240lb friend.
TH1RT3EN
posted September 14, 2010 03:02 PM
i was thinking the spool locations would no longer be applicable. thankfully the rear stand i have can be flipped both ways. Pads or spools. I should still be ok in that boat...
Patrick
posted September 14, 2010 03:13 PM
I have a Racetech spring that's a little stiffer than a Busa spring. If your interested email me eklipse636@hotmail.com
TH1RT3EN
posted September 14, 2010 03:31 PM
E-mail sent...
Patrick
TH1RT3EN
posted September 15, 2010 03:25 AM
I have been doing some checking and would the EK ZZZ chain be a reliable one to with for mainly street use? i have found it at a reasonable price new and just want to be sure.
Patrick
LAB3
posted September 15, 2010 05:20 AM
Yes... the EKZZZ 150 link chain and use a rivet chain press on the master link. Shane661 has a some pic's on his build thread that shows what to do. The chain guard tab gets in the way if you want to only go back 2 or 3 inches. The side of the tire will hit it. Use cut off wheel and remove the "L" tab from the inside of the swing arm.
Louis
TH1RT3EN
posted September 15, 2010 05:43 AM
should i still remove the tab if i want to go back 5"?
i am thinking it would be a good idea for the just in case aspect but not for sure.
I am also looking into making or purchasing an extended chain guard, I could probably make one way cheaper than i could buy one.
Patrick
LAB3
posted September 15, 2010 05:53 AM
Your fine that far back. Ebay has longer metal chain guards for about $50.00.
Louis
TH1RT3EN
posted September 15, 2010 06:05 AM
good deal, thanks for the info..
Patrick
0.24365496635437 seconds processing time
