BIKELAND > FORUMS > ZX-14.com > Thread: Spring NEW TOPIC NEW POLL POST REPLY
Douglas Home
posted September 14, 2010 04:16 AM
Spring
Im now 5" over & weigh 95KG.
Would replacing the spring on its own be worth it,
and what spring are people using at my weight.
The bike is daily transport also.
Doug Mackay Australia
CraigChrist
BAWLS
posted September 14, 2010 06:14 AM
You will hear people say both yes and no. My spring helped me tremendously, just because I was on an 07 model with the fuel pump that hangs way down and it made it so that I could launch with out bottoming out. A re-valve would be a lot better because the stock valveing just isn't enough to compensate, but if you don't have anyone to do it then ordering a spring would definitely be better than nothing. Especially if you could find a busa takeoff for cheap. Eklipse636 is about to have one for sale this week I believe, but I'm not sure what it would cost to ship it to you.
The spring that he has is a 13.8kg/in which is set up for a 185lb rider at 63".
60ft-------1.42
1/8th------5.97
mph-------119
Quarter Pounder
with Cheese
posted September 14, 2010 08:01 AM
yep, new spring and a revalve as the stronger spring blows through the stock valving. Extended you are asking way too much of the stock shock.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
posted September 14, 2010 08:08 AM        Edited By: Shane661 on 14 Sep 2010 16:21
The 08+ fuel pump is a direct swap and I just picked up a spare for $66 shipped, off ebay. If adding a spring or not, a good investment.
At your weight and wheelbase, I had no problems riding solo with the stock rear spring....street, LSR, and dragstrip.
It seems that a lot of people have swapped in stiffer springs, but later go to a re-valved shock. Some of the springs people are using are 800-1000 lb/in....whereas a typical high-end shock is 650-750 lb/in, with an increased damping range. For example, my Penske drag shock is only 650 lb/in. spring rate and has worked fine for me at up to 67.5" of wheelbase.
Obviously, high spring rates and stock damping will lead to an oversprung/underdamped condition. This may or may not be acceptable for your application.
0.26088619232178 seconds processing time
