BIKELAND > FORUMS > ZX-14.com > Thread: frame sliders install NEW TOPIC NEW POLL POST REPLY
bigblue14
posted September 13, 2010 06:32 PM
Can someone take a pic of the correct spot for the sliders. Im assuming its the open threads on the right side and removing the bolt on the left side right around the top 3/4 of the engine case. They just seem to be thin for holding a slider into place.
zixxer14
Damn that was Quick
posted September 13, 2010 07:14 PM        Edited By: zixxer14 on 14 Sep 2010 03:15
Pics of your sliders would help. If they're a single bolt install they probably replace the front upper motor mounts. There should not be open threads on the right, it sounds like you're missing a motor mount bolt. They are designed to bend slightly if you slide, hopefullly
without breaking off the mount. Install with red loctite & torque to spec.
bigblue14
posted September 13, 2010 09:08 PM
ok yeah i looked again it was a different point i can see from the pics just wanted to double check. thanks again
0.22123003005981 seconds processing time
