BIKELAND > FORUMS > ZX-14.com > Thread: My newly turbo'd 14 had flowing water up to the gas tank!! NEW TOPIC NEW POLL POST REPLY
Meangreen14
posted September 11, 2010 01:52 PM
On the 7th of this month there was some bad flooding in the earea and dint realize it till fire department was nocking on the door that it was that bad my newly turbo'ed zx14 was damn near under watering in the driveway and the fire department would not let me go move it because of the rising rapids, sooo I'm left with a debree covered engine mud and crap all over the bike, still waiting on insurance to look at it!
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
posted September 11, 2010 02:01 PM
take it all apart and clean it. sooner than later...
LAB3
posted September 12, 2010 11:55 AM
If you have not done so.remove the battery and and after the ins looks at it. tear her down. I bet you can get to run again. What a shame.....hope the electrics did not short out while the battery was still charged. Did you look in the gas tank and air box?? Plull the plugs and by hand turn the engine over and spray some WD-40 or what ever in the cylinders. Drain the oil now and see what come out.
1badzx12r
posted September 12, 2010 02:23 PM
x2 can't get it cleaned and lube fast enough. as long as its underwater everything ok but when air hits it.. rust city
posted September 12, 2010 02:54 PM        Edited By: Shane661 on 12 Sep 2010 22:55
Don't panic. Drain, WD-40 the cylinders, new oil. Run it and heat it up...drain oil and repeat a few times. You will be OK....change plugs when you are done.
Meangreen14
posted September 13, 2010 05:51 PM
Ok cool thanks guys, I'm still flushing oil lol
BIKELAND > FORUMS > ZX-14.com > Thread: My newly turbo\'d 14 had flowing water up to the gas tank!! NEW TOPIC NEW POLL POST REPLY
0.24714303016663 seconds processing time
