BIKELAND > FORUMS > ZX-14.com > Thread: Progressive Box Question NEW TOPIC NEW POLL POST REPLY
LeonidasZX14
posted September 08, 2010 02:07 PM
Has anybody wired up a progressive box and used the TPS as the WOT switch? I ordered a micro switch but my NOS mini has the capability of hooking right into the TPS. What are the pros and cons? I think that the micro switch will be easier to hook up but the TPS makes sense too. Which is best?
09' ZX14
Bently
2012 14r In Blue and no Mods!
posted September 08, 2010 02:53 PM
I can't speak for the nos mini, but my buddy has the new dyno tune one and his goes thru the tps and works flawless. pros to me are no micro switch to mount.
06redzx14
posted September 08, 2010 05:09 PM
I have my nos mini connected through the tps very simple install. Tapped my tps signal at the ecu
kingtramp
posted September 08, 2010 06:51 PM
The Nos Mini works off output voltage from tps switch to ECU, I believe the voltage setting in Nos Mini will be 3.9 volts which indicates full throttle opening on a ZX14. You can also change the voltage setting to a lower voltage setting to bring in nitrous before full throttle. Also talk with Dan about killing fuel injectors vice killing ignition coils during shift changes. Kiling fuel injectors vice coils greatly reduces back fire effect between shifts, NA backing ok. NOX back fire increases valve shim becoming dislogde and engine damage. If you going will a single fogger in air box give Chris Williams a call, he has a sweet set up.The yellow/white wire is the voltage wire at TPS to tap into. Also make sure you set Mini Ramp Pause Mode to P.01 if set to P.00 on each gear change it will start nos progression from the beginnig. P.01 will resume NOS from time of interuption.
LeonidasZX14
posted September 09, 2010 12:46 PM
Thanks Jim
09' ZX14
LeonidasZX14
Thanks Jim
09' ZX14
posted September 09, 2010 01:07 PM
Thanks Jim
posted September 09, 2010 01:08 PM
Thanks Jim
LeonidasZX14
posted September 09, 2010 03:29 PM
DICK
09' ZX14
posted September 11, 2010 02:00 PM
i had my schnitz window switch setup to use the GPS and used a microswitch on the TB. activated it as soon as i clicked second gear(or whatever gear you want)
LeonidasZX14
posted September 11, 2010 02:02 PM
06red, thanks again for taking the time out of your day to answer my questions via telephone. With your help I was able to get it set up!!!!
Chad
09' ZX14
kingtramp
posted September 11, 2010 10:51 PM
Chad Have you step into the DARK SIDE, button express ,
LeonidasZX14
posted September 12, 2010 03:19 AM
Just a small shot but I want to make the quick 16 at the bike bash thats coming up. Besides, I can't let Ellis and his Busa beat up on me.
09' ZX14
06redzx14
posted September 12, 2010 08:06 AM
No problem at all. Glad I could help
BLK ICE
posted September 12, 2010 09:02 AM        Edited By: BLK ICE on 12 Sep 2010 17:05
LeonidasZX14, I was told that the nos mini window switch is unreliable; so i wired in a normaly closed relay to the power commander hub's out put (triggered @50rpm after my shift point) to break the connection between nos mini and the tps. I did it so I would not spray into the limiter if I missed a gear.
kingtramp
posted September 12, 2010 09:06 AM        Edited By: kingtramp on 12 Sep 2010 17:10
"""Besides, I can't let Ellis and his Busa beat up on me"" Ellis had the misfortune of going down last nite @ Speed World , injuries to him are road rash to hands, overall Ellis is doing fine ,as for bike , heavy road rash to plastic on right side. No noticable case damage. Are you going to use spray bar, spyder or single nozzle? VP import fuel has given very safe results with nos..
LeonidasZX14
posted September 12, 2010 09:17 AM
I am using the dynotune kit which has a nozzle in each air duct. I was actually very suprised at the quality of the DynoTune kit. I spent half the money and got twice as much.
09' ZX14
01smokes
posted September 12, 2010 09:42 AM
HOLY SHIT man your using VP Import how big of a shot are you on? That fuel is what the BIG BIG BIG BIG dogs run when c16 and q16 is not enough lol
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
kingtramp
posted September 12, 2010 07:57 PM
Be safe not sorry,
01smokes
posted September 12, 2010 08:31 PM
Be safe not sorry,
hahaha i hear you when on the dop, how much is import anyways no one around here runs it so i have no clue on prices,
kingtramp
posted September 13, 2010 12:47 PM
Last can I bought in 09 was discounted at 112. I think it is now at 138 plus tax
Pretty Fast
posted September 15, 2010 04:58 AM
What exactly is the TPS?
06redzx14
posted September 15, 2010 05:21 AM
throttle position sensor
Pretty Fast
posted September 15, 2010 11:32 AM
Thanks 06red!
0.30067706108093 seconds processing time
