BIKELAND > FORUMS > ZX-14.com > Thread: clutch basket question NEW TOPIC NEW POLL POST REPLY
dcjens
Wet side of Washington
posted August 30, 2010 08:14 PM
I cant find my book and need to get the outer clutch basket off. I got a holder and got the inner off but am stumped getting the rest removed. how to? D
Black 06
Hellmutt
posted September 02, 2010 05:35 AM
Did you ever get anywhere on this dcjens? I just now saw this post, but unfortunately i'm at work and without my pdf manual..........here's a link if you're still in need
http://rapidshare.com/files/218324555/ZX14_Manual_and_Fiche.pdf
posted September 02, 2010 06:47 AM        Edited By: dubious on 2 Sep 2010 14:48
I put a penny between the primary gears, and torqued the nut off, easy as that....
been a while so I don't remember much else.
fast-14
posted September 02, 2010 09:13 AM        Edited By: fast-14 on 2 Sep 2010 17:18
canadian or american?
don't know how that angry face got up there. can't figure out how to remove.
'08 sapphire blue zx 14
still have a learners permit..
posted September 02, 2010 10:16 AM
haha, well a canadian one supposedly value is less,
but the US will surely keep printing more money, even when they can't possibly cover whats already on paper!
anyway...
dcjens
posted September 02, 2010 04:37 PM
No I havent got anywhere (job,girl)... but I did find something about a clutch gear setting screw in the manual. Again, still trying to get the big clutch housing off. It doesnt clear the case.
something about aligning "the teeth of the clutch housing gears by the gear setting" pg 6-14. I must not be spinning the housing around far enough to expose a hidden set screw?? Darin
Black 06
johnbull
posted September 03, 2010 08:26 AM
If you are trying to pull the clutch basket out but it wont come out because the outer gear hits against the casing then it is because you have not yet pulled out the centre bush between the shaft and the clutch basket bearing.
If you use a magnet on it and just move the basket in and out a bit it will come out.
Otherwise if I'm not mistaken the bush has a couple of threads in it so you can screw in a bolt and pull the bush out from between the shaft and the basket.
Untill you remove that bush you wont be able to get the basket out as it will keep hitting the caseing.
John Bul Racing. Malta.
dcjens
posted September 05, 2010 09:37 AM
Thanks John!
Black 06
0.30863189697266 seconds processing time
