BIKELAND > FORUMS > ZX-14.com > Thread: wastegate help NEW TOPIC NEW POLL POST REPLY
gilberjj
Friend of Fast
posted August 29, 2010 10:21 AM
wastegate help
What pressure spring are you guys using for your external wastegates? I want to run an external gate, with the spring pressure being my setting for pump gas. I think I remember Lee saying he had to use a 4 psi spring to get 6-7 actual psi....
Help!
01smokes
posted August 29, 2010 10:33 AM        Edited By: 01smokes on 29 Aug 2010 18:35
my spring is a .5 bar or 7.25 psi spring and it would show 7 on the gauge and every once in a while 8 but never more than that, what gate are you using? and how is it on the header post pics if you can
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
posted August 29, 2010 10:40 AM
Internal wastgates are more prone to creep. Never saw over 7 with a 6 lb. spring on the Busa.
posted August 29, 2010 10:51 AM
Jesses waste gate had some kind of problem and i have no clue what the cause was .. But anyway we had to run a 3 pound spring to get 5 or 6 psi .. We started with a 6 pound spring and we got 12 psi or so ..
01smokes
posted August 29, 2010 11:14 AM
than i had a simple manual boost controller and i would turn it up with that every pound was right at 15hp on my set up so easy to get carried away with boost lol
oldkawboy
posted August 29, 2010 11:55 AM
On my turbo ZRX I have 5, 7 & 9 pound springs and also supplied were 4 shims, you can use two for an extra one pound. It's a Turbonetics and they are within a pound according to my gauge.
Boost is so much fun !!!!
Dan
gilberjj
Friend of Fast
posted August 29, 2010 01:02 PM
ok..... I just ordered my mitsubishi 16g turbo (avoided the chinese stuff)
I'm thinking about cutting into the header and placing the wastegate right on the header instead of where the internal wastegate goes on the turbo..... I would think it would get more flow there..... What do you think?
01smokes
posted August 29, 2010 02:54 PM
01smokes
posted August 29, 2010 02:57 PM
you can get the parts from RCC to make it like mine it works damn good it never creaped it would hold boost good
gilberjj
Friend of Fast
posted August 29, 2010 03:22 PM
Thanks for posting up the pic. That looks great, I think I'll do the same kind of thing.....
01smokes
posted August 29, 2010 04:03 PM
and there is nothing wrong with them chinese turbos thats what is on my bike and its doing great hell im not even sure what size it is or anything
gilberjj
Friend of Fast
posted September 01, 2010 07:34 AM
I've heard mixed reviews about the chinese turbos. Some say that have had them for thousands of miles with no problems, but other say they exploded on the dyno on the first attempt. I found a mitsubishi 16g used for the same price as a new chinese 16g copy.... A no brainer if you ask me.
Big_T112
posted September 02, 2010 11:16 AM
I have never had one problem with a Chinese Turbo. The one 01smokes has made 390RWHP all day long and is a copy of a Garrett T3/04. and they are cheap.
01smokes
posted September 03, 2010 12:15 AM
yep and it was on 330hp for alot of HARD street miles and it never missed a beat hardly any shaft plat at all
NINJA12
posted September 03, 2010 08:09 AM
Which one would you recommend one for the CL header?
gilberjj
Friend of Fast
posted September 03, 2010 08:11 AM
type in "wrx 16g" in ebay. There are tons of them, and they cost about $275 shipped.
Big_T112
posted September 03, 2010 10:31 AM
what he said
posted September 03, 2010 10:53 AM
How do you modify one of these for an external wastegate?
gilberjj
Friend of Fast
posted September 21, 2010 10:30 PM
I'll make sure to post some pics when the time comes. If I go external (which is what I'm planning), then I'll weld in a divider plate to segregate the turbine wheel from the wastegate flapper, remove the flapper, cut a hole in the downpipe over the wastegate hole, and weld on an external gate.
gilberjj
Friend of Fast
posted September 25, 2010 11:38 PM
I was playing around on ebay tonight (cause I couldn't sleep), and I came across a BRAND NEW never used Tial 38mm wastegate for $119 shipped. Sounded too good to be true.... But I jumped on it because it had only been posted about 15 mins ago..... I wonder if the seller meant to start the bidding at $119 instead of a buy it now price at $119..... Either way, unless he's a deadbeat (and his score is 100%), that means I SCORED a NICE wastegate for a NICE price! Only sucky thing is it's a 14.7 psi spring.... Can't have it all
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=150498475017&ssPageName=STRK:MEWNX:IT#ht_500wt_977
NINJA12
posted September 29, 2010 08:34 AM
Looking to get the most HP out of the CL header, would you go with the 16g, 18g, vf22 or something else?
NINJA12
posted September 29, 2010 08:36 AM
Would I be better off with a different header, if so who's and how much?
gilberjj
Friend of Fast
posted September 29, 2010 01:29 PM
All other headers (that I know of) orient the exhaust on the other side (the exhaust exits on the left side and the intake is on the right side, exactly opposite of the CL kit). So, you'd need to get a COMPLETELY different setup. The 18g will flow 600 cfm...... that's a lot! What are you aiming for?
0.27693390846252 seconds processing time
