BIKELAND > FORUMS > ZX-14.com > Thread: Hard acceletation + high gear = engine slap/noise? NEW TOPIC NEW POLL POST REPLY
devilsidol
posted August 11, 2010 09:02 PM
I've read this problem before on here but couldn't find it. I think it has to do with the fly removal. Throttling hard on fourth and up gives a scary engine noise that sound like loose metal. It only lasts a second. Warranty is up soon and wondering if I should take her in. lots of mods and miles so not sure its covered anyway. Any help is appreciated guys ! 08 zx14 full muzzy pc3 w map flies out kn filter m1 4t 20w50. 8k on rebuilt engine. I usually run 10w40 but couldn't get it when I needed it.
Hellmutt
posted August 12, 2010 03:35 AM
Not sure if the viscosity difference would starve the cam chain tensioner much since it's basically hydraulic?? Don't know, but if you've still got some warranty time left -- I'd take her in!!
CraigChrist
BAWLS
posted August 12, 2010 03:56 AM
are you running a really low RPM when you go to WOT and then hearing detonation?
60ft-------1.42
1/8th------5.97
mph-------119
devilsidol
posted August 12, 2010 05:10 AM
I've never heard detonation before so possibly. It happens at 3700 rpm in fourth when hitting hard throttle but not WOT. I always run 93 octane and have never heard it before. Maybe my map was lost? Ill reload it, changeoil to 10w40 and get some new fuel in it. My warranty is on my engine rebuild so they might frown on the mods and say I'm on my own. Is detonation permanent damage or just temporary?
devilsidol
posted August 12, 2010 06:51 AM
68gts2
hobbies ( Beating you !!! )
posted August 12, 2010 10:25 AM
That's kind of what I wondered too. I got some bad gas not long ago and they don't ping like old carbed bikes. It was bad enough I went home and drained the tank before going any further. It did have a horrible sound that sounde like metal on metal when the the throttle was twisted.
posted August 12, 2010 01:03 PM        Edited By: dubious on 12 Aug 2010 21:06
detonation is mostly a temporary condition, but if left unnoticed can creat permanent damage, and severe damage at that.
I got a bad batch of fuel once and it pinged, made a clapping (diesel) sound at low rpm under high load, like more than 50% throttle at ~ 3000 rpm or less.
If your map is off, it could be back firing through the intake with a slight hesitation, then pulling away clean. It will feel like it stutters and pops, then takes off. Too much ignition advance can cause this too.
CraigChrist
BAWLS
posted August 13, 2010 05:03 AM
or it could be going way lean at 4k rpms with no flies...
60ft-------1.42
1/8th------5.97
mph-------119
0.31331610679626 seconds processing time
