BIKELAND > FORUMS > ZX-14.com > Thread: Fly Removal NEW TOPIC NEW POLL POST REPLY
DrBudgie
posted August 07, 2010 10:26 AM
Fly Removal
OK! Firstly I know this topic has been dealt with since 2006 so please respond with an understanding of what I 'perceive' to be correct....I have recently purchased a 14ZZR 2008 model and I have become acquainted to the low rev laziness of this bike, is it SAFE to remove the flies? The bike is a standard machine, all I've done is added two "Scorched" slip-on pipes (very popular in South Africa) similar to the "Yoshimura"
A healthy response would be appreciative.
THE MAD SOUTH AFRICAN BIKER
RACNRAY
FAST OLD GUY
posted August 07, 2010 11:14 AM        Edited By: RACNRAY on 7 Aug 2010 19:16
YES....remove the flies...it is safe. You will need to utilize a power commander to optimize the air/fuel ratio for best performance. Since the standard fly operation only has a negative affect on power below 6000 rpm's, that is where the air/fuel ratio will be most affected by fly removal.
All scoots benefit from fine tuning the fuel system to achieve the proper air/fuel ratio, so the power commander will benefit thru out the rpm range.
On my 2006 i removed the flies when i had the stock exhaust,a BIG difference was made in torque and acceleration in those lower rpm's. There was a slight leanness noted at cruise that caused a bit of rough runnin, but was not that bad. The 2008 and later 14's are not as lazy as the 06 7 07's, but yours will still benefit.
So do it!!
RACNRAY
no chicken strips on this south florida boy's skoots!!
chrisdhall
posted August 07, 2010 11:16 AM
I would recommend a PCIII or PCV with a suitable map. From the charts I've seen the bike will run very lean without it.
I removed the flies on my 09 and fitted the PCV/Autotune + Yoshi slip-ons. With a decent map the torque from 2000 to 4000 rpm is much improved. Actually I'd say the delivery from 2000rpm is vicious!
Chris
Quarter Pounder
with Cheese
posted August 07, 2010 12:07 PM
only remove if you are going to be remapping. Otherwise, leave it alone for now.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
Flame On
Fuel Air & Spark
posted August 07, 2010 02:31 PM
Remve those fuckers
77 RD 400
80 GS1000 GT
06 ZX14
zx14fan
posted August 07, 2010 02:36 PM
Dont bother you wont get much then you will need a pc.
Wheelie
Old Man
posted August 07, 2010 02:54 PM
have you guys looked at a 08 Brock map at 100% throttle at 3500 rpm?
wee
Lucky14
posted August 07, 2010 05:32 PM
wee
No, but 3750 is pretty interesting .........................
Wheelie
Old Man
posted August 07, 2010 05:41 PM
does pulling fuel mean that it's running lean?
wee
posted August 07, 2010 06:08 PM
+1
DrBudgie
posted August 07, 2010 10:27 PM
Thanx for the great responses! So a PCIII or PCV would have to be purchased first before the fly removal and I totally agree. Are there any particular differences between a PCIII or PCV or is one slightly better than the other? Secondly, am I able to purchase these directly from their makers without going to some South African importer.
Hey! Flame On! I really like your response pic LOL!!
BobC
posted August 07, 2010 11:39 PM
The main difference is that PCV is half the size of PCIII and Autotune plugs into it, you do need a lambda sensor though.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted August 08, 2010 05:19 AM
If no one wants to send you one overseas try www.starracing.com and ask to speak to Reed. I know he ships a lot of stuff overseas to people. Great guy to deal with.
INTIMIDA2OR
RED rider!
posted August 08, 2010 09:41 PM
Pull the flies and enjoy your bike even better
'06 Passion Red ZX-14
*Lee*
0.25213813781738 seconds processing time
