BIKELAND > FORUMS > ZX-14.com > Thread: Throttlemeister install NEW TOPIC NEW POLL POST REPLY
slates
posted July 19, 2010 05:59 PM
Just purchased a set of Throttlemeisters to reduce the vibrations and give my right hand some relief on longer rides. I have a some nice aluminum ones that I love the looks, but they hurt my comfort on any ride longer than an hour.
I haven't tried to install yet, but how many shims did most of you use when installing yours on the 14?
Quarter Pounder
with Cheese
posted July 19, 2010 06:11 PM
just have to try a shim and check, repeat until you get it where you like it. Simple
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
epd345
posted July 19, 2010 10:12 PM
Slates let me kmow how that goes they are in my list!
Hellmutt
posted July 20, 2010 07:37 AM
Mine too........just got the Buell pegs but haven't fitted yet to know how great they are to ride on
sweetfa65
posted July 20, 2010 02:48 PM        Edited By: sweetfa65 on 20 Jul 2010 22:50
Hi slates. I've got the throttlemeisters on my ride. As Quarter Pounder said, you just keep adding shims of various thickness until you get to the point where the throttle releases freely when it's released, and it only takes a small turn to lock on. I think I have 1 thick shim and one thin one on mine. Don't forget the plastic insert that goes inside the end of the throttle tube. Hope you got the heavy ones. That's what I got and they work extremely well with very little vibration..
'2013' SE Spark Black & Golden Blazed Green ZX14R. Bog stock after trading my 07 ZX14.
SteddyTeddy
posted July 20, 2010 05:29 PM
Another easy trick is to just loosen the throttle assembly and slide it over until it's just right. There is not set amount of shims to use. It all depends on where your throttle tube is locked down at on the bars.
posted July 21, 2010 10:49 AM
I was amazed at how simple it was to install on the Connie14
find the sweet spot with the shims allowing you to adjust the throttle while in locked down mode but still holding the position when your hand isn't on it
Georgia14
posted July 21, 2010 10:50 AM
does it make a big difference? can you tell on long trips?
2009 ZX14 with stock everything and
waiting on the warranty to run out to
upgrade.
Quarter Pounder
with Cheese
posted July 21, 2010 11:43 AM
big help on long trip. Any thing you can do that will allow you to relax your body or move around and be comfortable is priceless. This just allows you to relax your throttle hand and yes, you can tell on long trips.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
SteddyTeddy
posted July 21, 2010 11:47 AM
I just used the hell out of mine 2 weekends ago. 700 miles there and 800 miles home. Any type of a throttle lock is priceless on long trips!
posted July 21, 2010 12:23 PM
+1
YES sir!
sweetfa65
posted July 21, 2010 04:21 PM
+2 Throttle lock, bar risers and a good DB screen are worth their weight in gold on long trips.
sweetfa65
posted July 21, 2010 05:36 PM
+1 Also you can have enough shims installed so that when the Throttlemeisters are in the fully locked position, the throttle is just locked on. I have mine set so that only a minimal turn is required to lock the throttle. I can play with it to get a soft lock, so that you can still adjust the throttle by hand if needed, or locked on hard. That's a personal choice.
zixxer14
Damn that was Quick
posted July 23, 2010 06:42 PM
I've been using them on the last 4 bikes I owned. Priceless on long jaunts. You can convert them to other bilkes easily also with the shims.
epd345
posted July 23, 2010 07:10 PM
Just order the black one. Should be nice to relax the right hand on longer trips!
0.23830509185791 seconds processing time
