BIKELAND > FORUMS > ZX-14.com > Thread: Ok, A Little Advice . . . NEW TOPIC NEW POLL POST REPLY
GHOSTMAN
posted July 15, 2010 05:20 PM
I also posted this in the ZX6R Forum:
I have a friend who had to get her six lowered so she could actually get her feet on the ground. My question is, can she shorten the wheel base to eliminate some of the heavy feeling in the curves?
I'm There Whether You See Me Or Not.
Lucky14
posted July 15, 2010 05:37 PM        Edited By: Lucky14 on 16 Jul 2010 01:38
If it is lowered only in the back, the forks need to be slid up so the front matches the rear.
'Course, It's harder to do if you didn't measure everything first.
GHOSTMAN
posted July 15, 2010 06:09 PM
Yeah, the forks were slid up as well. Just wondered if shortening the wheelbase would eliminate some of that stretched feeling.
posted July 16, 2010 02:25 AM
If you try and shorten the wheelbase in the stock swingarm you could run into a problem of not having enough slack to get the chain on.(if that makes any sense).
LeonidasZX14
posted July 16, 2010 05:30 AM
Put on a bigger sprocket in the rear, that will shorten it up and give the bike a little more pep.
09' ZX14
Beondwacko
posted July 16, 2010 08:12 AM
Also, just a silly little tip,,,,,,,, how are the tires? If they are older and worn, that will slow the handling as well. Fresh rubber does wonders for initial tip in.
0.24677109718323 seconds processing time
