BIKELAND > FORUMS > ZX-14.com > Thread: I can't see sh*t with Low beams on NEW TOPIC NEW POLL POST REPLY
oilfieldtrash
Kawasaki enthusiast
posted July 11, 2010 04:37 AM
Is this normal? When I ride with low beams on only the two small outside lights are on and I can't see anything while riding. I have to use my brights. Should the two big lights on the inside be on when using low beams?
'07 white S.E. ZX-14 sold
LAB3
posted July 11, 2010 05:39 AM
Hey Shane........ yes the center two are Low beams. Check your fuse, etc.
Louis
1badzx12r
posted July 11, 2010 05:40 AM
yeap . check your fuse
oilfieldtrash
Kawasaki enthusiast
posted July 11, 2010 05:43 AM
Thanks I'll check it.
LAB3
posted July 11, 2010 05:47 AM
How is the engine doing? Any more crud in the oil?
oilfieldtrash
Kawasaki enthusiast
posted July 11, 2010 05:59 AM
Well the fuse was fine. The two center lights come on when bike is running but you can't see anything with just those on. I have to turn my brights on to see anything. Is this a problem for anyone else?
oilfieldtrash
Kawasaki enthusiast
posted July 11, 2010 06:02 AM        Edited By: oilfieldtrash on 11 Jul 2010 14:04
Havent changed it since then but it sounds great and runs like a champ. Drove into work today. Left 5 minutes later than usual. I thought I was gonna be late cause I'm usually at work 3-5 minutes before it starts and I ended up 10 minutes early. I usually drive my car. Cuts down on the driving time significantly on the 14.
LAB3
posted July 11, 2010 06:15 AM
My 14 low beams are adjusted too low to. I need to look in the service manual and see how to adjust them up a little. Glad to know the engine is running OK.
oilfieldtrash
Kawasaki enthusiast
posted July 11, 2010 06:34 AM
Yeah that's what I'm talking about. They got the things pointing to the ground.
Anyone ever adjust the low beams?
blackbullet76
posted July 11, 2010 06:39 AM
Yeah, takes a 10mm socket best I remember. I think you take off the ram air duct covers to expose the adjustment screws.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
1badzx12r
posted July 11, 2010 07:05 AM
the problem is ..when you adjust the low beams ..your also adjusting the high beams .. because bulbs are in the same housing
zx-14lvr
posted July 11, 2010 11:29 AM
keep the front wheel on the ground
bykw2
posted July 11, 2010 06:52 PM
I switch my low beams and hi beam to HID's they work great. I have a guy who sell the thin ballast hid's for $190 per set if anyone is interested....
epd345
posted July 12, 2010 01:25 PM
Yea I agree, the low beams alone are dangerous at night!!!!! I was considering a set of HID but I understand there is no way to adjust the beams once installed.
Hellmutt
posted July 12, 2010 05:42 PM
Really? Why is that? Do the HID's do away with the factory buckets/adjusters? All I did was swap the factory bulbs out for higher wattage bright whites -- gave me another 30 to 40 foot visibility both hi and low........cheap too!
LAB3
posted July 12, 2010 06:20 PM
Correct. Looks like about 3 full turns on the vertical adjustment bolt raised the low beam to a normal pattern that does not blind on coming traffic on low beam. Ride it with the ram air covers off so you can make final adjustments. This may differ from one bike to the next. Rider weight will make a difference as well as how you have your forks set. 2-44 in Service manual shows the vertical and horizontal adjusters.
BobC
posted July 12, 2010 11:41 PM
In Europe they don't allow HID's on a vehicle unless the beam height is self levelling and headlamp cleaning is fitted.
This for the comfort and safety of everyone else on the road. They also don't allow HID type bulbs in headlamp units designed for halogen bulbs as the beam pattern is not correct. Has the USA got road vehicle lighting regulations?
The projector type headlamps on the 14 work very well when properly adjusted.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
SLVR_BLT
Chicken Strips!
posted July 13, 2010 11:38 AM
That is the same laws here in the states however its rarely enforced unless the cop really wants to be a ass or you're running around with ridiculous headlight aiming and or light color way beyond normal like 8-12k kelvin.
As for the OP, maybe your headlight wires are crossed somewhere? The inner and outer lights should come on if you flip your highs on. I notice you said tiny lights, are you referring to the small parking lamp?
SLVR_BLT
Chicken Strips!
posted July 13, 2010 11:41 AM
No, the HID still allow full headlight adjustments, it works the same way as a normal bulb, only difference is it has a ballast attached to it. I have 55Watt DDM units and I will never ride without it, beam pattern and brightness is superb. Ill try to take a night pic later on to show its light pattern and brightness.
bykw2
posted July 13, 2010 08:11 PM
I don't see how that is the case when the only part yo are changing is the bulb.
Hellmutt
posted July 14, 2010 05:09 AM
Hey Lab - found the history on my buddies ebay account but the seller is no more........they were "xenon gas super white bulbs" ( simulated HID ) with 55/60 watt draw and 85/100 watt equivalent output........they're still available at roughly $20/pair from UK with free shipping
LAB3
posted July 14, 2010 05:51 AM
Thanks for looking. SlLVR_ BLT has some Bright lights too. I am looking at my options. For now just adjusting them is a Big improvment.
SLVR_BLT
Chicken Strips!
posted July 14, 2010 09:06 AM
Its better to just real HID for a little more money. In all my years of playing with stupid light bulbs from maybe 20 diff brands none of them really have any increased lumens (light output) in fact most of them just change light color but looks dimmer then the stock shit. The closest halogen based bulb that was semi worth it was the Silverstars but they don't last worth a shit.
posted July 14, 2010 11:00 AM
clutch the front up when you need to see further
LAB3
posted July 14, 2010 12:18 PM
Good One :-)
BIKELAND > FORUMS > ZX-14.com > Thread: I can\'t see sh*t with Low beams on NEW TOPIC NEW POLL POST REPLY
0.24660897254944 seconds processing time
