BIKELAND > FORUMS > ZX-14.com > Thread: Advice on cam chain tensioner NEW TOPIC NEW POLL POST REPLY
indynic
Lil Show, Lil Go
posted June 30, 2010 04:25 AM
I was at the track last night and let my bike sit for about an hour. When I fired it up it took about 30 seconds for the "rattle" to go away. There was a guy there that owns a motorcycle performance shop that was trying to scare me into buying an APE manual tensioner and have him install it.
I have done some research on this and there are mixed reviews. Is my bike a ticking time bomb? Is this long of a rattle normal? (I thought that everybody had the rattle) Sometimes is rattles for two seconds, sometimes for 15-30 seconds.
Could I just replace the stock cam chain with a new one if it is getting worn?
Here is a quote from SMOKIN I found when I was searching...Does this still hold true?
Ok lets put this to rest ....The zx14 uses a rachet type adjustor ... Oil pressure is used to push out the plunger into the cam chain guide ... The rachet holds the adjustor from backing off ...So at high RPMs backing off the throttle the adjustor does NOT back off ...
The reason you have start up rattle is the adjustor has not caught the first grove in the rachet ... With a few miles the chain will get a bit longer allowing the adjustor to to grab the first grove in the rachet ...I ride mine hard and the start up rattle stopped around 2500 miles ..If you ride easy it may take a few more miles but the start up rattle will stop at some point .. The point is there is NOT a problem and i have yet to hear of someone having a problem with the cam chains on the zx14 ..
My 09 zx14 does NOT have the start up rattle and that leads me to believe they did a little fine tunning on the 09 adjustor so it would rachet to the first grove without waiting for the cam chain to get longer .. It makes no sence to mod a zx12 adjustor to fit a zx14 ..Unless you have a full out drag bike with a built motor i see no need for a manual tensioner either..
PLEASE HELP!!!!!
1badzx12r
posted June 30, 2010 04:32 AM
buy a busa .. thay don't rattle
Could I just replace the stock cam chain( TENSIONER) with a new one if it is getting worn?
yes you can the CCT gets worn also and replacement fixes it for a while
dcjens
Wet side of Washington
posted June 30, 2010 04:57 AM
http://www.bikeland.org/board/viewthread.php?FID=27&TID=54772&set_time=
Your bike is behaving normally and there's nothing wrong with it. I've put 20,000 miles on my bike and it rattled on start up every time. You can get the APE and have it installed or try this. rattle gone. Or do nothing.
Black 06
reypac24
Old Fart!
posted June 30, 2010 07:31 AM
try a modified zx 12 tensioner. i replaced mine 2 years ago and haven't heard anymore noise. now you engine guru's can chime in anytime but i think the low oil pressure these bike run make the 14's cct prone to this.
Rey
Red 2006 ZX-14: Green 2000 ZRX-1100; Blue 1977 KZ-1000 LTD;
indynic
Lil Show, Lil Go
posted June 30, 2010 08:37 AM
I appreciate the feedback. The noise really does not bother me, so I would like to do nothing. I just want to make sure that something catastrophic is not about to occur....Especially if I can prevent it.
LAB3
posted June 30, 2010 09:50 AM
They don't stop worth a damn either. I told you to fuk more and eat less and you would not need a turbo.
Oh ................ fuk a Booza. I think they are ugly. You will miss shifts with it too. :-)
A modded ZX-12 CCT is a good fix if you don't want to manual adjust.
LAB3
posted June 30, 2010 09:58 AM
Rey
Or the oil drains out of the bore in the CCT. Just a thought. Who machined your ZX-12 CCT?
Louis
1badzx12r
posted June 30, 2010 10:26 AM
like i'm going to take orders from a moron on a zx14 .. well i did do screwed everything you own
posted June 30, 2010 10:32 AM
99 to 2001 busa had a big CCT problem ... When the busa CCT let go it took out the head and valves and pistons ..Just cause you got a busa doesn't turn the bike into a saint .. Saint Busa has pleanty of problems as you will find out very soon ...
LAB3
posted June 30, 2010 10:57 AM
Put that donut Down......... fatso. You can't spell, you can't ride and all you do is act like a ass.(FAT)
You can't ride a train without someone helping you. LMAO I guess Jr. High must have been tuff on
you.......... J/K Now go cry at the Busa.org about how you can't shit without someone drawing you a picture first.
reypac24
Old Fart!
posted June 30, 2010 12:34 PM
Louis
sorry for the late reply Louis, electricity and internet are on/off due to hurricane Alex.
i bought mine a couple of years ago here on this site from Bill Eason.
Rey
1badzx12r
posted June 30, 2010 12:57 PM
you talk alot of shitt for a guy that does nothing ..come get some .. say for a 1000.00.. i can see your crawfishing already ..
LAB3
posted June 30, 2010 01:50 PM
I'm to Busy fukin................... North Texas hillbillie LMAO.. Go work on the Booza....turbo picking on
a Old man with a street 14. Your 1bad .......... :-)
LAB3
posted June 30, 2010 02:26 PM
Louis
Rey
Thanks Rey
Hope all is OK, just some rain here in Fort Worth, Tx.
Louis
1badzx12r
posted June 30, 2010 02:35 PM
for your info old crawfish eating man ..i have 5 bikes ..3 are bone showroom stock . and 2 turbo . but yeah i'd use the turdbo ..nobody ever wants a close race
blackbullet76
posted June 30, 2010 09:20 PM
My 07 rattled like hell all the time, even when riding at low rpm's. I installed the APE tensioner, and I'm glad I did. No more rattle and runs better too. I recommend gettting one.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
indynic
Lil Show, Lil Go
posted July 08, 2010 06:50 AM
So...Is my bike gonna blow up or what? My threads always seem get jacked for some reason.
SMOKIN...Does what you stated in my earlier post still hold true?
dhobbs74
posted July 08, 2010 07:13 AM
I need to do something about mine also, I've noticed that my rattle seems to be getting worse at startup. I started it up last night at bike night and people looked over at with an expression on their face like "What the hell is wrong with your bike" It does go away after about 15-30seconds but its annoying as hell.
reypac24
Old Fart!
posted July 08, 2010 07:35 AM
http://www.bikeland.org/board/viewthread.php?FID=27&TID=35802&set_time=1196900579
LAB3
posted July 08, 2010 08:20 AM
Have you tried to turn off engine after 15 seconds and re start ??? 30 seconds on a tight engine with
good oil pressure is Not Normal CCT noise.
If my engine Ever does it that long I will either have a ZX-12 CCT machined or do the manual adjuster.
Sorry for thread jack a few posts back.
dhobbs74
posted July 08, 2010 09:37 AM
Well let me take that back I wouldnt say its 30 seconds i would say about 10-15seconds. It goes away if I blip the throttle but I still dont like rattling like that. Im gonna just have another CCT put in and see what happens
Y2KZX12R
CompetitionCNC.com
posted July 09, 2010 06:00 PM
Put a zx12r tensioner it it and be done with the worries.
Put it in a lathe and cut .120" off the flange surface.
A warning to anyone running cams and springs..... get that garbage stock tensioner out of there.
Y2KZX12R
CompetitionCNC.com
LAB3
posted July 09, 2010 06:24 PM
Do you do this mod?
Y2KZX12R
CompetitionCNC.com
posted July 10, 2010 04:55 AM
Yes we do. But all you need is to find someone with a lathe. Its very simple and takes about 5 minutes.
Y2KZX12R
CompetitionCNC.com
LAB3
posted July 10, 2010 07:51 AM
Thanks PM sent....as will funds for new ZX-12 CCT machined.....Thanks
Louis
0.31081318855286 seconds processing time
