Lou D
posted June 10, 2010 06:19 PM
valve cover
My beautiful sapphire blue 14 has developed that nasty oil leak from the valve cover. Can someone tell me the washer size that is used for the fix under the bolts?
TooHype
Go Hard or Go Home !!
posted June 10, 2010 09:06 PM
It is a M10 washer
posted June 10, 2010 09:53 PM
all the part #'s Kawi replaced incluing those are in this thread, and it DID NOT "permanently fix my leaky Harley wanna be ZX14. Its leaked again after a few thousand miles.
But here is all the info of what Kawi replaced to stop the leakhttp://www.bikeland.org/board/viewthread.php?FID=27&TID=26799
TooHype
posted June 10, 2010 10:23 PM
The washers are actually a cheap, quick, wonderful solution. They have totally and definitly stopped my leak even after several thousand miles all is dry.
Hellmutt
posted June 11, 2010 05:57 AM
So this only affects the early year 14's? I've got an '08 with no problems.......as of yet I'm having no problems -- just want to make sure I won't need to do this too
TooHype
posted June 11, 2010 08:09 AM
I noticed the leak on my 07 around10,000mi then did the washer fix around 13,000, I now have19,800 on the bike and have no leak at all. I have to believe that the problem is solved. The whole idea just makes since. If your 08 ever starts to leak I would possibly sugest the same remedy. Quick. Simple and cheap.
posted June 11, 2010 08:17 AM
find a washer that matches the size of your valve cover bolts shim it and forget it. I had a slight seep afer 11000 miles on my 06 and at 14000 its is seep free.
Lou D
posted June 11, 2010 04:56 PM
Thanks guys. I think mine started leaking when I switched to Mobile 1. Does anyone know the torque specks on the bolts?
TooHype
posted June 11, 2010 10:16 PM
quote: Thanks guys. I think mine started leaking when I switched to Mobile 1. Does anyone know the torque specks on the bolts?
I seriously doubt if Moble 1 oil had anything at all to do with the leak.
87 in·lb is the valve cover torque spec.
biggmoinc
posted June 12, 2010 09:11 AM
@Too Hype, maybe its was just ur bike crying when that 12 went by u, lol, sike just playin, whats up wit a ride this weekend, bout to take my daughter to a bday party but afterwards she going to mommom house for the night, imma outta here, lol
biggmo@aol.com
LAB3
posted June 13, 2010 06:55 AM
+1 on both of his posts M10 washer. Oil is not the problem.
Hey another Louis. lol
