BIKELAND > FORUMS > ZX-14.com > Thread: Anyone ever used Rockett Brand fuel? NEW TOPIC NEW POLL POST REPLY
gilberjj
Friend of Fast
posted June 07, 2010 11:31 PM
http://www.rockettbrand.com/productspecs/specs.html
I'll be building a turbo bike over the winter and I'm beginning even now to collect parts for the build. Originally I had planned to do a full fuel system and run e85. However, the cheaper fuel cost isn't really that practical for a pure race bike when the stock fuel system should provide me with enough fuel for 280ish whp. Would I be ok on the 100, 111, or 114 octane? The reason I ask is because the 100 octane unleaded fuel is around $7.00 per gallon. Much more reasonable then c16.... By the way, how much do you guys pay for c16? I got quoted for $70ish/ 5 gallons.
Compton
posted June 08, 2010 03:17 AM
590 delivered for 54 gallons of C16.
never used rockett brand, i only use VP or PowerMist fuels. I don't trust the other brands.
b.w.
Quarter Pounder
with Cheese
posted June 08, 2010 05:58 AM
gotta give VP the nod as well....how well you take care of it will also play a major role.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
Big_T112
posted June 08, 2010 08:08 AM
I ran up to 12 pounds of boost on Av gas strait from the airport. Here it's about $3.40 a gallon, it's 100 Oct. You just have to take a gas can. they want let you drive your bike up and put it in the tank.
posted June 08, 2010 09:29 AM
The octane required will be dependent on the boost and timing control.
kawa74
posted June 08, 2010 03:17 PM
AV gas
Stick with VP, Go to their web or call them, they won't steer u wrong , AV gas has high octane , but low BTU's , burns slow , , airplane engines rev low ,like 3000 ,bikes have to have Fast burn , less time , U can mix AV with prem 50/50 , but gravity, BTU's still low , Been there done that wrong ,
"I have never met a man so Ignorant that I coun't Learn from him"..."Galileo"
gilberjj
Friend of Fast
posted June 08, 2010 03:44 PM
It's not av gas....
0.26058602333069 seconds processing time
