BIKELAND > FORUMS > ZX-14.com > Thread: Bike dies after warming up NEW TOPIC NEW POLL POST REPLY
zx14dreamin
posted June 07, 2010 09:15 AM
I have an 08 SE and in the morning before I take off, I let it warm up, I will leave when the RPMS drop to around 1000 rpm , the last few times, it starts to stumble when the rpms drop and eventually dies, I can start it right up, and after I ride this does not happen, should I just adjust the idle?
reypac24
Old Fart!
posted June 07, 2010 10:23 AM
1000 rpm is a little low, try 1200 rpm. a higher idle will also help oil pressure.
Rey
Red 2006 ZX-14: Green 2000 ZRX-1100; Blue 1977 KZ-1000 LTD;
INTIMIDA2OR
RED rider!
posted June 07, 2010 11:42 AM
Rey
What he said.
'06 Passion Red ZX-14
*Lee*
posted June 07, 2010 11:53 AM
swap it for a HONDA
zx14dreamin
posted June 07, 2010 01:41 PM
Rey
What he said.
ok I will try raising the idle, this is how it was set from the factory after warming up it would always drop down to a little under 1000 rpm.
Thanks for you advice`
Wheelie
Old Man
posted June 07, 2010 01:47 PM
stumbling doesn't sound like a low idle problem, you have a aftermarket pipe and pc?
wee
INTIMIDA2OR
RED rider!
posted June 07, 2010 02:05 PM
Rey
What he said.
Then it was set wrong cause when the bike is warmed up it the FSM says the idle should be 1000 +100 rpms.
So like above 1000.
*Lee*
INTIMIDA2OR
RED rider!
posted June 07, 2010 02:11 PM
wee
Well he says it stumbles when the rpm's drop. It makes sense for the engine to stumble if it's idling too low cause the engine wants to keep running but can't run too low and will tend to stumble before it shuts off.
Now if he means it stumbles while the idle is still high cause of the cold start then dies cause of it then that is a completely different problem.
*Lee*
SLVR_BLT
Chicken Strips!
posted June 07, 2010 03:01 PM
Mine hovers around 1100ish rpm. Idles smooth as a Lexus.....well besides that loud exhaust noise.
INTIMIDA2OR
RED rider!
posted June 07, 2010 03:13 PM
Lol!
*Lee*
zx14dreamin
posted June 07, 2010 08:12 PM
yeah it stumbles when it gets to low in the RPM's , I have no aftermarket parts on the bike yet. its just strange that it has started to do this now after 8k+ miles, though it seems the idle has creeped down a little lower than it was before which was just under 1000. I will have to take a look at the manual tomorrow and see how to adjust it to 1100 after warmup.
INTIMIDA2OR
RED rider!
posted June 07, 2010 08:24 PM
Keep us updated.
*Lee*
blackbullet76
posted June 07, 2010 08:57 PM
I have my 07 set at around 1300
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
INTIMIDA2OR
RED rider!
posted June 07, 2010 10:55 PM
Mine is just above 1000 . It has stayed perfectly set since about 15k miles.
*Lee*
brooksie
posted June 08, 2010 05:36 PM
How many miles on the bike? Is it low on coolant?
posted June 08, 2010 06:44 PM
check and adjust your throttle cable free play, and adjust the idle for 1000 rpm warm.
Mine would idle smooth even as low as 850-900 when I was adjusting it, but thats not good for the valvetrain, oil pressure and flow is too low.
Mine liked the spark plug change after 8000 miles too. ran much smoother. Others wil debate this statement to death, but thats what I found.
I also liked running sea foam through it every oil change to clean out the combustion chambers and injectors
zx14dreamin
posted June 15, 2010 05:39 AM
ok so yesterday I got the chance to adjust my idle and this morning when I started her up and the idle settled down, she stayed running, I had set it around 1100. I am 900 away from 10k miles I will change the plugs then, oil and put seafoam in . Thanks for your advice. Dubious, did you use any special or different spark plugs? Or just what Kawa calls for?
INTIMIDA2OR
RED rider!
posted June 15, 2010 10:41 AM
I stick with the Iridiums that come stock.
They are plenty good
*Lee*
0.32040786743164 seconds processing time
