BIKELAND > FORUMS > ZX-14.com > Thread: Speedohealer...how accurate? NEW TOPIC NEW POLL POST REPLY
blackbullet76
posted June 02, 2010 09:07 PM
How accurate is the 14 with a correctly calibrated speedohealer at high speeds?
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
Superman T
posted June 03, 2010 01:17 AM
Spot on! I have one due to 16T front/43T rear
BobC
posted June 03, 2010 03:20 AM
The accuracy depends on you knowing what offset to apply, get that right and it will be perfect.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
zixxer14
Damn that was Quick
posted June 03, 2010 06:03 AM
I set mine with a gps, so it's as accurate as that is.
LAB3
posted June 03, 2010 08:13 AM
+1 when I went 16/43, then had to change again when I installed a 55 series rear tire.
I have the heal tech that has the pig tail with a button so I can store a set set of #s.
blackbullet76
posted June 03, 2010 11:08 PM
I have mine set to a 16 tooth front and stock rear with stock rear tire size. Hit 170 the other day according to the top speed recall, was just curious. Thanks guys!
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
0.39451885223389 seconds processing time
