blackbullet76
posted May 31, 2010 09:16 PM
Clutch reservoir fluid level
My 07 14 has about 11,000 miles on it now with only a few trips to the dragstrip. I'm wondering if I'm needing a new clutch because the fluid level in the reservoir is close to the "low" level, but the clutch feels fine.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
INTIMIDA2OR
RED rider!
posted May 31, 2010 09:22 PM
Top it back off . You should be fine.
If you pull the oil fill cap off and pull the clutch lever in and take a look down at the cluch you can see how close your fibers are getting to metal.
'06 Passion Red ZX-14
*Lee*
blackbullet76
posted May 31, 2010 09:44 PM
Ok, thanks. I just checked the clutch plates (never thought of checking them like that before) and they looked fine. Any specific fluid I need to top it back off, or will brake fluid work?
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
INTIMIDA2OR
RED rider!
posted May 31, 2010 10:06 PM
I use the motul RBF 600 brake fluid cause it gives a good lever feel and a pretty high boiling point.
But yes you can use a good DOT 4 fluid too.
*Lee*
blackbullet76
posted June 01, 2010 06:51 AM
Ok, thanks man!
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
SLVR_BLT
Chicken Strips!
posted June 01, 2010 03:30 PM
quote: I use the motul RBF 600 brake fluid cause it gives a good lever feel and a pretty high boiling point.
BIG 2nd, or you can use a cheaper close alternative ATE Superblue if you're semi broke. When i first got my bike, it had old fluid from 2006 so the boil point was way down in 4 years of service. It got to the point on a hot day with my bike cruising slow traffic my clutch lever freeplay was getting tighter and tighter, it got to the point it was preloading the clutch because of fluid expansion. It ended up slipping the clutch at WOT that whole day. Once i flush that shit out that clutch problem went away. I didn't think old fluid would ever do that.
gilberjj
Friend of Fast
posted June 01, 2010 03:42 PM
I bought Valvoline synthetic cheapo dot 3/4 stuff from napa, and I hotlapped the piss out of my bike with no problems. 14 passes in a couple hours. I would say 7 passes were in the last hour.
SLVR_BLT
Chicken Strips!
posted June 01, 2010 03:46 PM
Make sure it at least meets DOT 4. That's what the manual specifies.
blackbullet76
posted June 01, 2010 10:20 PM
Yeah, I read the cap after I posted that. Guess I should have looked. I also have a book on it. That would have told me too.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
INTIMIDA2OR
RED rider!
posted June 02, 2010 12:07 AM
But the book isn't as good as the info you would get on this site ... And not as much fun either
*Lee*
blackbullet76
posted June 02, 2010 05:55 AM
Very True :-)
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
debo33
posted July 28, 2013 07:05 PM
If i use dot 3 in my reservoir will it cause shift problems.... Reason i asked i bleed clutch and then refilled with dot 3..is it possible tht it gt too hot and stopped it from shifting..need help... Abt to go into tranny
Lonnie Anthony
debo33
posted July 28, 2013 07:06 PM
Lonnie Anthony
