BIKELAND > FORUMS > ZX-14.com > Thread: Front wheel removal.....problems NEW TOPIC NEW POLL POST REPLY
mike_zx14
New York
posted May 31, 2010 12:56 PM
Pulled the wheels off today to drop off at the dealer and ran into some problems getting the front off.....
I loosened the pinch bolts on the bottom of the forks and stll needed about a 4ft piece of pipe on the end of the ratchet to break the damn thing loose..Anybody else have trouble pulling the front for the first time ??
Also this tool in the pic is all I needed to pull the front off the 12r do I need a second one on a 14 ?? It only fit the left side (if your facing the front of the bike) but not the right..
Big Mike..
2007 ZX14 Candy Plasma Blue, Brocks Gen III, Brocks Map, PC III, Heli Risers, BMC Air Filter, GEL Grips, Vortex Rear Sets, Puig Windscreen, Dunlop Q2's, Amsoil, Engine Ice, No Flies, and No chicken strips..
LAB3
posted May 31, 2010 01:16 PM        Edited By: LAB3 on 31 May 2010 21:17
No leave one side pinch bolts tight until you losen the axle nut with the tool you have.
Both sides are 22MM but the other side is not deep enough for the hex to go in very deep. Leave that side pinch bolt tight and lossen the the other side and use your tool. Then loosen the other side pinch bolts and slide out axle.
posted May 31, 2010 01:21 PM
I have had an axle seize like that before.
mike_zx14
New York
posted May 31, 2010 01:45 PM
Never even thought to do that.......Thanks man !!
Big Mike..
mike_zx14
New York
posted May 31, 2010 01:48 PM
She was a bear to get broke loose, I'm not exactly a fly weight either !!
You the same Shane that used to be on the 12r forums that Ship, Voz, 238mph, NinjaNick, and all those cats hung on ??
If so Big Mike from the same here...
Big Mike..
posted May 31, 2010 01:51 PM
Yes, I am that guy...I go by Warp12 there, and on most other boards.
mike_zx14
New York
posted May 31, 2010 02:20 PM
Roger that, I used to get a kick out of you and Ship going back and forth !! Since I bought the Jeep I haven't ridden much or hung on the bike forums.....I did promise myself this summer I was gonna ride more, kind of a shame to let a 14 sit like I have.......sold the 12r two summers ago..
Big Mike..
0.24253511428833 seconds processing time
