BIKELAND > FORUMS > ZX-14.com > Thread: How to adjust the timing on 07 zx-14??? NEW TOPIC NEW POLL POST REPLY
KDZX14
*ZX-14Chic*
posted May 27, 2010 10:39 PM
Hey guys! Have a couple quick questions. k....we have two ZX-14's 06-07 on the 07 my hubby is trying to figure out where to and how to adjust the timing on the stock motor to advance to timing?? Is this possible without buying that Ignition module you see that is used with the power commander USB?? Any help will be greatly appreciated!!
Thanks,
Kristy
gilberjj
Friend of Fast
posted May 27, 2010 10:56 PM
You can get the muzzy timing advancer. It mechanically advances the timing from the pickup point, so you advance the entire ignition map equally. From what I've seen, very little gains can be had from simply advancing timing on a stock motor zx14.
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=4923047&showprevnext=1
Btw, welcome to zx14.com
posted May 28, 2010 04:32 AM        Edited By: dubious on 28 May 2010 12:32
Muzzy sells a timing plate.
Depending on your set up of course, you might find a couple HP, but many didn't liek that the bike ran hotter, and some have had issues with advancing it, especially on the 08 or newer, caused flat spots if the fuel map was slightly lean already
welcome to the circus.
posted May 28, 2010 04:56 AM
You can do it with a fixed advancer, which will not allow fine adjustment across the rev range.
You can do it with a Dynojet Ignition Module, which allows for fine adjustment.
You can also do it with an MSD SB6 module, which has a host of additional features.
WRECKSHOP
posted May 28, 2010 08:20 AM
Its better to do it with the Dynojet Ignition module because you have more adjustablity and it does alot better job than the Muzzy ignition advancer. Just call Ivan at Ivan Performance products and he will sell you one with a custom programmed ignition map already installed into the Dynojet Ignition module and TRUST me it works very well too.....
KDZX14
*ZX-14Chic*
posted May 28, 2010 09:08 AM
Hey guys, Don't think my other post reply came thru bc i don't see it?? Anyways...Thank you all that replied so quickly! So tell me do you think it's gonna be a waste of time with the timing thing on a stock motor?? Any other tips on how to get a lil more HP would be greatly appreciated as well Oh and THANKS FOR THE WARM WELCOME
HERE ARE A FEW THINGS DONE TO THE 07 ZX-14
Adams arm 12" over
Muzzy side winder
Muzzy custom map for the PCIII
PCIII
BMC air filter
Butterflies removed
Orient Express Air Shifter
U4-4 Race fuel
Sprokects 1 down on front 4 up on rear
We are running on an 1/8 mile track!
Best time i've been able to run was 5.79 1/8 Now i'm stuck in the 5.90's since we changed the exhaust, swing arm and sprokects. Thinking about changing the custom map and see if that helps any.
Thanks Guys
Kristy
dickhead
posted May 28, 2010 11:16 AM
Try MR9 or MR 12 fuels.
SLVR_BLT
Chicken Strips!
posted May 28, 2010 02:25 PM
Isnt there a Ivan's TRE as well?
posted May 28, 2010 06:15 PM
Try a 48t rear sprocket. It works!
KDZX14
*ZX-14Chic*
posted May 30, 2010 09:21 AM
GREAT ideas guys We tried the TRE already didn't really work to well with him.
The MR9 fuel, Don't you have to take out whats left in the tank or it will do some damage LOL?? But have been thinking bout running that fuel.
eklipse636: Thanks will def have to give it a try!! So u think it's gonna make a difference in the 1/8 with goin from 47 to a 48 in the rear???
Thanks again guys!!
Kristy
speedgene
posted May 30, 2010 03:58 PM
"Nobody listens to Turtle."
Just observing that "1bad" move.
"Ho Ho Ho, Greeeeeen Giant."
E-tard
LAB3
posted May 31, 2010 01:37 PM
Depends on what you want from a TRE. The TRE 006a I have STOPS the de-accell pop.
Period.... with out it my 14 sounds like a small pistol going off at 3500 RPM. FACT.
How are those muffler bearings working for you? :-)
Louis
posted May 31, 2010 02:01 PM
Thanks again guys!!
Kristy
4 up in the rear would be a 45. After I tried it I won't go back. Dropped a good .05-.07 off my 60ft
KDZX14
*ZX-14Chic*
posted May 31, 2010 02:28 PM
eklipse636: If you don't mind me asking.....what all is done to your bike, is it stock or??
Kristy
KDZX14
*ZX-14Chic*
posted June 01, 2010 03:31 AM
WOW and I thought all along it was a 47t rear WTF? maybe goin up would make a difference then huh?? since we only have a 45t rear.
speedgene
posted June 01, 2010 07:07 AM
KD, You have this "Hall Effect" at that magnetic pin and the legs of that tone wheel. You move out of that wave form, she both will not run; then too remember, how are you going to bring the cam's degree with you?
Now, if you could change the maps inside the ECU, that would be ideal. Anything else, you are messing with and upsetting that magnetic field on the outside. Get it? Sorta?
E-tard
KDZX14
*ZX-14Chic*
posted June 01, 2010 04:44 PM
Sorta, LOL
KDZX14
*ZX-14Chic*
posted June 03, 2010 10:47 AM
Hellmutt
posted June 03, 2010 01:44 PM
Louis
I had the same TRE on mine, and it worked very well eliminating decel pop with street riding, but for strip use you won't see any improvement IMO.......and KD, the couple fella's I know that run 1/8 drag are using 48 tooth setups for better #'s.......eklipse is right on the money with that one
KDZX14
*ZX-14Chic*
posted July 01, 2010 03:30 AM
quikgix
posted July 01, 2010 11:21 AM
Kristy I'm using mr-12 and I like it alot, my best 1/8 mile time is 5.73 @123mph at 64" wb. 16-43 gear, strapped ,lowered Brocks sidewinder and map,shinko hook up with 20psi, air shifted I'm leaving at around 7,500 rpm and 60' 1.40-1.45 all day long. I'm 180 in street clothes.no timing advancer.
1352cc 8.39@159mph on motor cant wait to spray this bitch
0.31592082977295 seconds processing time
