BIKELAND > FORUMS > ZX-14.com > Thread: 2007 r1 wheels NEW TOPIC NEW POLL POST REPLY
gilberjj
Friend of Fast
posted May 26, 2010 03:24 PM
2007 r1 wheels
I might have a chance to pick up some r1 wheels cheap. I LOVE the look of the simple thin 5 spoke wheel, plus they look really light. I know this is a long shot, but does anyone have any clue about their weight, axle size, fitment, ect...? Has anyone seen these mounted on a zx14?
gilberjj
Friend of Fast
posted May 26, 2010 03:25 PM
gilberjj
Friend of Fast
posted May 26, 2010 03:29 PM
Good news.... front brakes are the same size.... 310mm
posted May 26, 2010 03:29 PM        Edited By: Shane661 on 26 May 2010 23:34
I would start by investigating the axle diameters, and rotor diameters. Should be easy enough to find.
Then check the front rotor spacing.
gilberjj
Friend of Fast
posted May 26, 2010 03:33 PM        Edited By: gilberjj on 26 May 2010 23:34
workin on it... found out the rear sprocket is 45t. That's cool
gilberjj
Friend of Fast
posted May 26, 2010 03:36 PM
06 r1 le is front axle 22mm diameter, 159mm between fork legs
What are the zx14 numbers?
posted May 26, 2010 03:39 PM        Edited By: Shane661 on 26 May 2010 23:41
I really don't recall the diameter #'s...check Ron Ayers!
Distance from leg to leg is not really an issue (you will need proper spacers anyway). The big issue is rotor spacing.
Compton
posted May 26, 2010 03:48 PM
and if you only use one rotor it's even easier
b.w.
gilberjj
Friend of Fast
posted May 26, 2010 03:52 PM
Ya, I planned on it. If I'm going to be making my spacers, I should be able to line up at least 1 brake disc with the zx14 caliper.
knydecker
Uber-BigPimpin
posted May 26, 2010 06:09 PM
God I wish I was not so big!! I love the R1. Great bike and awsome looking!!!
This was dictated... but not read!
zx14fan
posted May 26, 2010 09:11 PM
I would think that the integrity of the wheels could be compromised with the added hp and weight? Those wheels look good I thought about getting a set but would hate to break one.I could be way off on that though.
zx14fan
posted May 26, 2010 09:12 PM
Also I dont know if a 190 tire would fit right on that wheel?
dakota9498
posted May 26, 2010 09:22 PM
That bike came with a 190 tire. Also, the horse power wouldn't be that different, the torque would and that shouldn't affect it. Weight might...
2008 ZX14
gilberjj
Friend of Fast
posted May 27, 2010 07:38 AM
So you suggesting that an additional 80lbs distributed between both wheels is enough to break one? I would hate to see what would happen then if a 300lb dude were to come down hard from a 12 o'clock wheelie if that were the case. They are made with a lot of safety margin built in..... The heft from a zx14 is no different then a heavy rider on an r1. They are designed to not only withstand jumping (haven't you seen the isle of man), wheelying, ect, with a huge person mounted, and they are made to deal with it for a LONG time. The stresses of drag racing are minuscule compared to road racing (which is what this bike was built for).
Quarter Pounder
with Cheese
posted May 27, 2010 07:45 AM
you can simply swap out bearings with proper I.D and O.D to fit in the wheels and use the 14 axles. Then make some custom spacers to get them spaced correctly. Will be interesting to see how it works out. Love the look of those as well.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
posted May 27, 2010 08:18 AM        Edited By: SteveWFL on 27 May 2010 16:19
if you're near Tampa we can pop the wheels off mine and see exactly what you're up against
I'm about to change to wave rotors and Michelin Pure tires, and lose several more pounds off the front
gilberjj
Friend of Fast
posted May 27, 2010 08:20 AM
if you're near Tampa we can pop the wheels off mine and see what you're up against
Thanks for the kind gesture, but I am about as far from Tampa as I could possibly get (Washington state).
I think I'll just buy the wheels and go from there. My buddy is only asking $200, and I could always sell them for more then that if it doesn't work.....
posted May 27, 2010 08:27 AM
GEEZ $200? damn right buy the wheels!!!!!!!!!!!
zx14fan
posted May 27, 2010 11:57 AM
There is some sort of reason that the 14 comes with what it has.The zx 10 wheels didnt come on the bike. im sure kawi wants to have a little more strenth because of the lbs and hp.
dakota9498
posted May 27, 2010 11:59 AM
So everyone just leave their ZX14s stock because Kawi put that stuff there for a reason and we can't make it any better.
2008 ZX14
SLVR_BLT
Chicken Strips!
posted May 27, 2010 12:27 PM
I think wheels are typically engineered to take 2.5 times its rated capacity. Similar to tires there is alot of overhead it can take before they actually fail. I think they will be fine on a ZX14.
If it can haul this ass, im sure the R1 wheels will be fine lol
gilberjj
Friend of Fast
posted May 27, 2010 12:28 PM
I guess you can be the first person in-line to say "I told you so" when the wheels explode into 1000 pieces. Until that time, use common sense when posting. I already tried explaining this to you..... The zx14 wheel and r1 wheel, and any other motorcycle wheel for that matter has a strength margin built into its design. They take the maximum capacity (probably around 1200), and then probably triple it for good measure. I never carry a passenger, and I don't subject my wheels to the rigors of road racing. If you still can't understand, or just disagree, I don't care. Go bother Lyle for a while.
SLVR_BLT
Chicken Strips!
posted May 27, 2010 12:59 PM
I guess anythings possible, this guy claims he was just riding and all of a sudden his wheels gave out...i think there is more to his story but there was no damage to the rim itself like running over a curb etc.
gilberjj
Friend of Fast
posted May 27, 2010 01:06 PM
You can be second in line to say "I told you so."
SLVR_BLT
Chicken Strips!
posted May 27, 2010 01:13 PM
Haha, im not saying that will happen, because there is usually headroom when wheels are engineered but anything is possible. It could happen to a set of stock wheels that came with your bike.
0.22325801849365 seconds processing time
