BIKELAND > FORUMS > ZX-14.com > Thread: Mcintosh NEW TOPIC NEW POLL POST REPLY
Wheelie
Old Man
posted May 25, 2010 04:45 PM
Mcintosh
installing my Mcintosh, the threaded spanner nut isnt going to go inside the swingarm like it does on the stocker, is it supposed to ride up against the new swingarm?
wee
LeonidasZX14
posted May 25, 2010 04:51 PM
Wee
I believe so, but let me go take a look
09' ZX14
Wheelie
Old Man
it doesnt move smooth
wee
LeonidasZX14
posted May 25, 2010 04:54 PM
I remember something wierd when I put that nut on. I just went and looked at it but could not tell anything special. There are roughly 6 threads showing and if I remember right the castle nut was flush and had no threads showing on the stock arm. One other thing, are your links adjustable?
09' ZX14
LeonidasZX14
posted May 25, 2010 04:55 PM
Move the arm up and down 20 times then re check the tourque.
09' ZX14
Wheelie
Old Man
posted May 25, 2010 05:22 PM
still kinda stiff,
wee
posted May 25, 2010 06:10 PM
Call them.
>ook<
Wheelie
Old Man
posted May 25, 2010 07:10 PM
its on, I will see what Mcintosh says tomorrow,
wee
LeonidasZX14
posted May 26, 2010 02:26 PM
Did you notice that the Mac arm made your bike sit much higher?
09' ZX14
Wheelie
Old Man
posted May 26, 2010 07:01 PM
yeah the tire didnt rub the tigertail, a dirty Black Angus
wee
Lucky14
posted May 26, 2010 07:48 PM
I like it!
I like it a LOT!
LAB3
posted May 27, 2010 02:39 AM
What is the WB now? Looks good Wee.
Wheelie
Old Man
posted May 27, 2010 03:08 AM
need to measure, I think its about 69", and it doesnt weigh 15 lbs as stated a 15 over does, it weighs 22 lbs and its 12 over
wee
posted May 27, 2010 05:48 AM
Looks good!
salsa1
posted May 27, 2010 06:43 AM        Edited By: salsa1 on 27 May 2010 14:47
Mickey Thompson makes a 17 " drag slick if traction becomes an issue with the tire that far back wheelie...just loose info....but the tire is available...I use it and it hooks far better than any ultra shinko I have ran (could be too much with no wheelie bar but tire pressure can help control that too) ).....would have to be regeared if used it is a taller tire than a shinko or stock
http://www.mickeythompsontires.com/motorcycle.php?item=ETDragMotorcycle&sku=3221&size=26.0/7.0-17&type=MC
Bike looks good.
Salsa1
biggmoinc
posted May 27, 2010 07:27 AM
i like the looks from what i can see, post some brighter pics please! N what super size sprocket u gonna run now that ur even longer?
biggmo@aol.com
Wheelie
Old Man
posted May 27, 2010 08:47 AM
I will get some when I get home, staying with a 16-48
wee
Wheelie
Old Man
posted May 27, 2010 09:16 AM        Edited By: Wheelie on 27 May 2010 17:26
Bike looks good.
round slick is working good, not sure if it will hold on a -1.29 60'
wee
kawasakijockey
posted May 27, 2010 09:28 AM
Bike looks good.
wee
If you get a 1.29 60ft on that stock motor at your weight, well, I'll..I'll...Well,I dont know what...
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
dakota9498
posted May 27, 2010 09:53 AM
Bike looks good.
What abou the Mickey Thompson ET Drag Radial, anyone tried that one?
2008 ZX14
salsa1
posted May 27, 2010 09:54 AM
1.29 60 ft is excellent.....just theory that the farther back the less weight on the tire and could theoretically result in less traction...but I believe this is more of an effect with a solid strut in the rear.....you run a monoshock so it may not be an issue....as long as your are satisfied with your 60 ft...
you will know where you are at and what at to do when you try your present set up...just a heads up options are available with a Mickey thompson that hooks more than a round profile tire...and the compound is better for dragracing I believe also....thats all....
Salsa1
kawasakijockey
posted May 27, 2010 09:56 AM
He is too heavy. Wont happen.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Wheelie
Old Man
posted May 27, 2010 12:45 PM        Edited By: Wheelie on 27 May 2010 20:48
wont happen? a 1.29 60'? what about 5.60's?
wee
posted May 27, 2010 12:53 PM
Bike looks good.
wee
Shinko slicks are working here with 70 inch wheel base bikes ... One of our friends has been mid 1.20s 60 footer and 5.24 in the 1/8 mile ..
posted May 27, 2010 02:25 PM
No flat slick!!
0.22462296485901 seconds processing time
