BIKELAND > FORUMS > ZX-14.com > Thread: Need some measurements please NEW TOPIC NEW POLL POST REPLY
gofastica
posted May 24, 2010 09:49 PM
I'm working on a custom project, and exploring several options. I would appreciate it if anyone has the ability to measure a couple things for me.
I need to know the diameter of the rear axle, the swingarm width at the axle from chain adjustment bolt to chain adjustment bolt, and the distance, center to center, between a rear brake rotor mounting hole and the mounting hole directly across from it.
If possible, millimeters would be awesome, but I'd manage otherwise.
Thanks.
68gts2
hobbies ( Beating you !!! )
posted May 25, 2010 02:02 AM
Welcome to the forum.The person you need to talk to for your measurements is Shannon at Old Scchool Racing. He just finished a wheel conversion kit and will probally be able to help you out with those deminsions.
0.23157382011414 seconds processing time
