BIKELAND > FORUMS > ZX-14.com > Thread: It could have been my imagination...but NEW TOPIC NEW POLL POST REPLY
SixSixoh6
posted May 18, 2010 09:00 PM
I swear when taking my 95 mile trip from one residence to my hometown, every now and again i swear i seen my speedometer needle just drop all of a sudden while cruising 70-75mph. and then return back to normal. As some of you have read on my earlier posts ive been having some cluster issues. Curious is this all leads back to that damn Bonneville box.
Anyone else seen that happen on these bikes?? I could be due for an eye appointment as well lol
dogg24
posted May 18, 2010 10:54 PM
I have the Bonneville box and haven't had any problems so far.
2012 ZX14R SE, Streetmeg, PCV
TooHype
Go Hard or Go Home !!
posted May 18, 2010 11:13 PM        Edited By: TooHype on 19 May 2010 07:14
I use a SpeedoHealer and have heard some horrible things about it but I havent had any problems yet.
LAB3
posted May 19, 2010 03:27 AM
+1 but most were bad ground. Another person posted the Muzzy box did the same thng. Sometimes speedo needle would go up and down then be OK??? Several others posted No problems with the Bonneville Box. Check all the hook up wires and ground wires.
dakota9498
posted May 19, 2010 10:29 AM
I have that same problem with my Bonneville Pro. It doesn't have a ground wire, just a two connectors that go between the Speed Sensor and the ECU and you splice into one wire that goes from the ECU to the Speedometer.
It may be a general ground problem, but I haven't had any other issues and didn't have this issue until after I put on the Bonnevile Pro.
2008 ZX14
posted May 19, 2010 12:10 PM
I have been using a speedo healer for 4 years with no problems
SixSixoh6
posted May 19, 2010 08:12 PM
Yeah, im not sure the issue either. there are plug and play connectors as well.
LAB3
posted May 20, 2010 02:49 AM        Edited By: LAB3 on 20 May 2010 10:50
Check general ground to cluster. And check pins on plug and play. Almost two years with Speedo healer and no problems. Changed gearing 3 times now. :-)
SixSixoh6
posted May 20, 2010 01:54 PM
Bah, yeah ill just to check those "plug n play" deals. Sometimes thats not always the case!
BIGZXDADDY
posted May 21, 2010 08:31 AM
i have the speedo healer and was having the same problem last year but mostly while riding in light rain. i applied stabilant the terminals in the speedo healer connectors and it has not done it since
"never drive faster than you can see, besides it's all in the reflexes"
0.2458610534668 seconds processing time
