BIKELAND > FORUMS > ZX-14.com > Thread: Driven sprockets arrive 16-43 now need differnce speedeo NEW TOPIC NEW POLL POST REPLY
robrooter
posted May 13, 2010 10:12 PM
Hi all sprockets an chain arrived today 530mvx2 Ekquadra-x ring going from 16 -41 to 16-43 dose any one no the callabration for the speedo healer v3.0 thanks in advance.
Sprockets are driven..
Ride it, Respect it, It can an will bite you when you least expect. /smilies/smile.gif" border=0>
Newf14
2007 ZX1400
posted May 14, 2010 03:09 AM
-14.9 should be good.
Newf14
LAB3
posted May 14, 2010 05:49 AM
I just changed to 16/43........ Hold On. Driven rear in black steel. Kaw Zephyr 16 front. Had to adjust chain 2 times. The dampner material on the sides of the front 16 had to wear in from the
chain links.
posted May 14, 2010 07:00 AM
stock errror 8%
change in gearing = 11%
-19% total
dakota9498
posted May 14, 2010 11:30 AM
Mine was only 11 or 12 percent total with that gearing, verified by two different GPS's.
2008 ZX14
posted May 14, 2010 12:56 PM
they must be making the speedo more accurate then.
The math says 11% alone
dakota9498
posted May 14, 2010 01:29 PM
That is what my math said as well, I put it at 11%, but it is actually somewhere inbetween 11 and 12% because 12% puts it just above actual. I would rather it read 1 mph or less slower vice the other way around.
2008 ZX14
LAB3
posted May 14, 2010 01:43 PM
At 70 MPH what is your RPM?? I am 16/43 but have 190/55/17 rear so my math is different.
My speedo healer has a pig tail for a second set of corrections. Looking for box for part# and re-check the site.
dakota9498
posted May 14, 2010 01:52 PM
I don't know what RPM I am running at 70 to be honest with you I really never run 70. But I have a Muzzy Bonneville Pro on mine.
2008 ZX14
LAB3
posted May 14, 2010 02:11 PM
Muzzy did not make this when I got a healer. Cool no speed limiter and correct speedometer. Don't think that will be a problem with 16/43 and you have a 50 series rear. 170 something now. I need to do the math and reset mine for taller rear tire.
dakota9498
posted May 14, 2010 02:33 PM
I got it planning for a trip to Maxton. I am transferring to Virginia Beach in a few months, so I will finally be back on the right coast.
2008 ZX14
robrooter
posted May 14, 2010 06:42 PM
thanks guys 2 weeks till the bike gets back
zx14fan
posted May 15, 2010 12:03 AM
do not listen to dopy.trust me on this.
posted May 15, 2010 02:17 PM        Edited By: dubious on 15 May 2010 22:21
your a jack ass, contributing the same drool and dribble as usual.
absolutely useless .
anyone who does a search will see that the speedo is about 8% optomistic, and your leaving top speed on the bench if you don't correct for it.
There are countless others since 2006 that have witnessed the same thing
ask lee what his dyno shows for speedometer error.
dakota9498
posted May 15, 2010 02:57 PM
I concur, the speedo is about 8% optimistic in stock form, verified with GPS. And I thought that it would be more that the 11% that the math showed as well, but it didn't work out that way.
2008 ZX14
0.27535510063171 seconds processing time
