BIKELAND > FORUMS > ZX-14.com > Thread: Need help with Goodridge 2 line front brake set-up. NEW TOPIC NEW POLL POST REPLY
sweetfa65
posted May 12, 2010 10:26 PM
I've got my new Goodridge rear, and 2 line front brake lines. I can't work out the best routing for the new lines, or if both ends of the lines are the same or not. I want to get myself sorted out before I start, so I can just get the job done without messing around. Can someone who has installed a two line front brake set-up help me out please. My bike's stripped down for some servicing and mods, and want to get the lines on while it's apart.
Any advice would be appreciated.
'2013' SE Spark Black & Golden Blazed Green ZX14R. Bog stock after trading my 07 ZX14.
68gts2
hobbies ( Beating you !!! )
posted May 13, 2010 02:46 AM
I think I still have my instructions saved. I will look after work,if I do I will gladly scan them and post them for you this evening. Well actually my wife will since my computer skills um hum ah suck, yea that's it.
sweetfa65
posted May 13, 2010 03:14 PM        Edited By: sweetfa65 on 13 May 2010 23:16
Cheers 68, That'd be great. I was surprised they didn't come with any. I emailed the Goodridge guys and they just said route the best way possible. Really helpful.....NOT
68gts2
posted May 14, 2010 04:03 AM
instructions
68gts2
posted May 14, 2010 04:10 AM
Sweetfa sorry it took so long Bro,planning a wedding and got busy getting adresses last night. Hope they help you out. I had to purchase a mighty-vac to bleed mine,worth every penny. Peyton
sweetfa65
posted May 14, 2010 05:21 PM
Thanks dude. Big help. Yep, just got myselv a mityvac too. Will let you know how I go.
68gts2
posted May 15, 2010 05:20 AM
I added a couple of black zip ties in hidden areas to kep them together.
sweetfa65
posted May 17, 2010 01:26 AM        Edited By: sweetfa65 on 17 May 2010 09:30
Thanks for the instructions. It's the first time I've tried this upgrade. I don't want to tie you up with the weddin and all. Just a few questions: Did you run your lines in front or behind the throttle cables? The instructions say use the original fasteners, but the left one's on the top and in the wrong spot. How did you fasten them on the guard? Any pics anyone has of the routing and mountings for a two line set-up would be great. Cheers.
68gts2
posted May 17, 2010 05:21 AM
I will post some pics at lunch.
68gts2
posted May 17, 2010 04:40 PM
sweetfa65
posted May 17, 2010 10:59 PM
PM sent 68gts2.
0.23380589485168 seconds processing time
