BIKELAND > FORUMS > ZX-14.com > Thread: I keep hitting brick walls building this turbo bike NEW TOPIC NEW POLL POST REPLY
mink
posted May 09, 2010 09:08 PM
im looking for a header for a gt28rs ...chris jones ..richard from rcc ..barry henson..and muzzys all a no go... i would like right side exhaust and have the turbo mounted as high as possible ....figured i would ask before i start building my own ...any pics would also be helpfull thanks in advance
gilberjj
Friend of Fast
posted May 09, 2010 11:01 PM
The only right side exit I know of is Cycle Logic. They base their kits off ihi subaru turbos though........
gilberjj
Friend of Fast
posted May 10, 2010 12:07 AM        Edited By: gilberjj on 10 May 2010 08:13
I was thinking about it, and the gt28rs (aka "disco potato") turbo is one of the best upgrades for subarus. So, that would be a great turbo to use with the cycle logic turbo kit. Plus, they are selling cheap on ebay right now.
full kit
http://cgi.ebay.com/ebaymotors/Kawasaki-ZX-14-zx-14r-zx-14R-TURBO-KIT-/160426983313?cmd=ViewItem&pt=Motorcycles_Parts_Accessories&hash=item255a317f91
There is also a partial kit that has been popping on and off ebay from $500-$600. It's a smokin deal for headers, oil pump, exhaust pipe, inlet pipe, and a couple other do-dads. I don't know much about the cycle logic kit though. I never looked at it because I don't like ihi turbos, but the disco potato (gt28rs) would be a perfect turbo for a bike. wicked spool.... I'm sure lyle (dubious) will chime in. He knows a lot about the turbo kits offered, and I remember him saying that the map was way off with the cycle logic kits.
gilberjj
Friend of Fast
posted May 10, 2010 12:12 AM
I found a bolt-on gt28rs for a wrx (which would fit the cycle logic header flange)
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Product_Code=ATP-SUB-003&Category_Code=SUB
I think I remember seeing this same turbo on ebay before at around $1250 too.....
good luck..... I'm going to bed
XLR8S
posted May 10, 2010 02:51 AM
I think my header is a Cycle logic, not sure though because I bought it off e-bay. It looks like it has been cut and modified with the T-25/GT flange. I'll try to get some pics posted up. I'm using a GT2854 which seems to spool "real" fast.
ZX14, 1 piece at a time............. Roger
boostphreak
posted May 10, 2010 10:55 AM
the cycle-logics uses the three bolt flange that has the third bolt way out from the other two.And the header places the turbo in the middle of the motor right next to the oil cooler and pretty tight to the motor so you are limited to the size of turbo you run. on the other hand they are made of stainless. the exhaust pipe is stainless also but it goes under your pan so you cant run a flat pan
0.42688918113708 seconds processing time
