BIKELAND > FORUMS > ZX-14.com > Thread: 660cc injectors installed NEW TOPIC NEW POLL POST REPLY
wrongway
posted May 05, 2010 06:43 PM
I put in the new 660 cc injectors . I had to go from a +60 all the way back to 0 on the power commander. I still have the 70 psi pump in there , so I will change that out tomorrow an go back to a stock pump and start making a map.
I got this set from Five 0 motorsports. there were a few installion issues , but I am sure bruce will have all that sorted out after I get him some pictures and info.
these injector have the same connector as stock , and the final installation needed a .250 spacer under the rail mounts.
Roy
1badzx12r
posted May 05, 2010 06:56 PM
how much
gilberjj
Friend of Fast
posted May 05, 2010 07:46 PM
very cool. How much?
wrongway
posted May 05, 2010 08:27 PM
$280 .....
Roy
Y2KZX12R
CompetitionCNC.com
posted May 06, 2010 03:06 AM        Edited By: Y2KZX12R on 6 May 2010 11:07
Roy, are these bosch? whats the number on the side of them? The 550 and 660's.
Y2KZX12R
CompetitionCNC.com
1badzx12r
posted May 06, 2010 03:08 AM
$280 .....
Roy
GOOD PRICE ..i been ebay hunting for sometime ..
wrongway
posted May 06, 2010 05:36 AM
they didnt have numbers molded on them like the stock ones did. there are some small numbers printed on the 550's , but I cant read them. The paper work that came with them say Bosch LS9 , 550 cc @ 3 bar . the tops were machined down. the pig tail adapters are nice.
.... I am not sure on the 660's,
Roy
wrongway
posted May 09, 2010 06:55 AM
the 660 cc injectors seem to be the correct size for the 1530 cc motor with E85. At WOT at 10k I am only adding 10% on the power commander .
There seems to be plent of headroom for nitrous now . I was able to get the AFR down in the 10's without having to use big numbers .
Roy
0.23251104354858 seconds processing time
