BIKELAND > FORUMS > ZX-14.com > Thread: brake problem NEW TOPIC NEW POLL POST REPLY
kaw-rick
posted May 05, 2010 12:20 PM
brake problem
What you thinks going on with this? changed tire out for a buddy. now got a problem with brakes. Seems that if you roll bike 2 feet it doesnt have brakes. Pump lever 1 time it has brakes. roll a couple feet more no brakes. it always needs 1 pump b4 brakes come back. Reservoir is full. we only took the callipers off to get wheel off. thanks b4 hand .
gilberjj
Friend of Fast
posted May 05, 2010 12:24 PM        Edited By: gilberjj on 5 May 2010 20:26
.....scratching head.....
calling mulder and scully
kawasakijockey
posted May 05, 2010 12:32 PM
The small port at the master cylinder might have a spec of trash in it.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
SixSixoh6
posted May 05, 2010 12:42 PM
the front or rear? i can say mine did the same thing somewhat after putting it back together this winter. My front wheel anyways..it eventually went away. not sure what caused it either
INTIMIDA2OR
RED rider!
posted May 05, 2010 01:08 PM
Possible that the rotor got bent during the tire change.
'06 Passion Red ZX-14
*Lee*
posted May 05, 2010 01:09 PM        Edited By: Shane661 on 5 May 2010 21:10
Definitely sounds like a bent rotor. When the rotor spins around it is pushing the pads apart. I bent one on my 12R and it acted this way, and I have seen others have the same issue.
INTIMIDA2OR
RED rider!
posted May 05, 2010 01:12 PM
I hate when a weel comes back from a tire changer and the rotors are bent.
It doesn't take much to tweak a rotor.
*Lee*
kawasakijockey
posted May 05, 2010 01:20 PM
The way to check that is to not move the bike at all and pull the lever. If it only does it when the bike moves then these guys are right, a bent rotor.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
kaw-rick
posted May 05, 2010 03:46 PM
thanks guys. we will check that next.
dbryant1400
The Candy Red Devil
posted May 05, 2010 04:24 PM
sounds like air in line somehow. need to bleed brake
Donnell Bryant
russ8526
posted May 05, 2010 04:29 PM
+ 1 on bent rotors
2007 zx-14 Limited
Brocks Alien Head
BMC Race Filter
PClll w / Track Map
Flies Removed
16 T Front Sprocket
Speedohealer
Fender Eliminator
INTIMIDA2OR
RED rider!
posted May 05, 2010 09:10 PM
*Lee*
0.41612386703491 seconds processing time
