BIKELAND > FORUMS > ZX-14.com > Thread: turbo motor NEW TOPIC NEW POLL POST REPLY
boostphreak
posted April 30, 2010 07:04 PM
turbo motor
Iam building a new turbo motor, je pistons, ape studs, valve springs, new bearings, etc. My question is what about the oiling system? what is there to the billet oil pressure valve and cover? Is it needed and how can it benefit my turbo application?
zxbob
posted May 01, 2010 05:54 AM
The oil pressure valve & cover are a good mod . . . . . turbo or not !
It'll keep better pressure to the bearings ~ allways a +
Bob
1badvespa1400cc
power junkie
posted May 01, 2010 06:06 AM
any pic's?
Just another foeteen!!!!!
Stu64
posted May 01, 2010 11:09 AM
If you have the motor all apart its a no brainer ,do it.
I am just finishing up installing a stage 1 turbo kit on my bike and that was one of the first things i wanted to do after hearing about the #3 bearings having low pressure. Plus your pressure drops a little from the turbo feed line.
Valve itself is easy to do,the pump plate sorta sucks to install ,but i installed new clutch plates anyways.
0.52413988113403 seconds processing time
