BIKELAND > FORUMS > ZX-14.com > Thread: Standing behind your product.... NEW TOPIC NEW POLL POST REPLY
dakota9498
posted April 29, 2010 11:26 AM
Well, I changed the gearing on my bike and wanted to get the speedometer to read correctly. I was going to buy a speedohealer but have seen enough stories about those screwing things up so when I saw the Muzzy's Bonneville Pro come out I thought that would be perfect.
I received it and installed it and it works...thankfully because after I was finished I read the warranty statement and saw this.
So if it had been bad I would be screwed. I am still tempted to take the damn thing off and send it back to them and tell them where they can put it.
Regardless that is the First and ONLY thing I will ever buy from them.
2008 ZX14
oilfieldtrash
Kawasaki enthusiast
posted April 29, 2010 01:24 PM
Yeah pretty chicken shit stuff there.
'07 white S.E. ZX-14 sold
CraigChrist
BAWLS
posted April 29, 2010 02:35 PM
typical muzzys support.
60ft-------1.42
1/8th------5.97
mph-------119
dakota9498
posted April 29, 2010 02:38 PM
Yeah, I figured you would like that one...lol
2008 ZX14
INTIMIDA2OR
RED rider!
posted April 29, 2010 02:59 PM
Wow that's pretty bad! Its almost as if they already know their parts are gonna fail and they are letting you know before hand lol!
'06 Passion Red ZX-14
*Lee*
68gts2
hobbies ( Beating you !!! )
posted April 29, 2010 03:00 PM
Any electrical part has the same basic disclaimer on it now a day. Reason being a lot of dip sh!ts hook stuff wrong and want the manufacturer to eat it because they fried it on install. All my a/c electrical parts have the same disclaimer. That being said,It Does Suck,Dakota.
dakota9498
posted April 29, 2010 03:05 PM
I hear you, but even so, my DynoJet PCIII didn't have a disclaimer like that. Or anything that I can remember recently. A lot of them do say do not return it to the store or distributor to return it directly to the manufacturer, but to just say I know you paid 150 bucks for this, good or bad you are stuck with it is just plain dirty.
2008 ZX14
kawasakijockey
posted April 29, 2010 03:11 PM
That is a basic electrical component disclaimer. You cant see if a hermetically sealed component was wired wrong and shorted. They could swap out three of them before the customer realizes he wired it wrong in the first place. I sold lots of electrical parts and the manufacturers did not warranty anything unless it was installed by an authorized vendor(me).
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
SixSixoh6
posted April 30, 2010 03:04 AM
ive got the box as well. mine does not work coreectly and is hooked up properly. i can tell you im not shelling out another $150 for one. the speedo reads fine, its just the gear indicator
Compton
posted April 30, 2010 03:10 AM
the gear indicator read slow, sixsixoh6? if so, thats normal even with a speedohealer
b.w.
SixSixoh6
posted April 30, 2010 03:13 AM
it has always read slow, but after the box install it doesnt read the right gear period
#1 gear-----1 on dash
#2 gear-----2 on dash
#3 gear-----3 on dash
#4 gear-----blinks 4 then goes to 5 on dash
#5 gear-----5 on dash
#6 gear-----5 on dash
posted April 30, 2010 05:53 AM
that's about the same thing you see with a speedo healer set to -8%
zixxer14
Damn that was Quick
posted April 30, 2010 06:05 AM
Just put a piece of black tape over it & pretend it's not there. That's what I do for my "check engine" light in my truck. Can't see it, don't worry about it.
INTIMIDA2OR
RED rider!
posted April 30, 2010 10:37 AM
My gps tells me what my speed is so I'm good
*Lee*
dakota9498
posted April 30, 2010 11:07 AM
My Bonneville allows the gear indicator to read normally, and it workswell, it has about 1mph difference from my GPS. I am -1/+3 and the dial is set at 88% (-12%).
2008 ZX14
68gts2
posted April 30, 2010 11:14 AM
So I take it that means that. -1/+3 is only 12% off then Dakota?
dakota9498
posted April 30, 2010 11:16 AM
It is probably about 12.5, but that is the closest one. If i put it at 13% it reads a little slower.
2008 ZX14
SixSixoh6
posted April 30, 2010 11:30 AM
yeah im not so sure what the deal is with my gear indicator, as long as it doesnt affect anything else on the bike.
mine is set at 89% for -1 +2 gear
gilberjj
Friend of Fast
posted April 30, 2010 01:20 PM
The gear indicator is just an estimation by the ecu of what gear you're in based on rpm and speed. So, whenever you gear the bike, the gear indicator gets all screwy. Unless the Bonneville changes that, I believe that's just the nature of our bikes....
RACNRAY
FAST OLD GUY
posted April 30, 2010 03:08 PM
I installed a Cometic thin head gasket on a stock motor Busa bout 3 years ago. I have a 3 stage torque/retorque process when i put heads on that pretty much eliminates any problems with head gaskets. Bout 5000 miles after this was done the head gasket leaked across the bores. When i contacted Cometic bout the failure of their head gasket on a stock motor, that was the EXACT statement they sent me. I had to eat the job, including sending the cylinder out to millenium to have the deck ground flat again.
Sneaky u know whats.
RACNRAY
no chicken strips on this south florida boy's skoots!!
gilberjj
Friend of Fast
posted April 30, 2010 03:42 PM
RACNRAY
............. That's because it was a head gasket...... not electronics. If you put pistons in a bike and rode it for 5k miles, would you expect any warranty?
Electronics are one thing (dynojet has been great to me), but when you put something in a motor, there are WAY too many variables (and stupid riders/builders) for a company to back internal components. The only company I know of that has such a good warranty on parts is Turbonetics. 1 year no questions asked warranty...... which is crazy....... but I would still go Borg Warner or Garrett over TurBLOWnetics
osr
posted April 30, 2010 07:09 PM
MUZZY Sucks Big Donkey Balls!
dakota9498
posted April 30, 2010 07:14 PM
lol...my thoughts exactly. I can't remember who it was, maybe SteddyTeddy will remember. But there was a guy on the ZRXOA that had Muzzy's build and engine for him, and after it was done they wouldn't even tell him the specs of the motor. Wouldn't give him cam specs, what they were degreed too, compression ratio or anything. After I read that I told myself then that I wouldn't ever mess with them....oh well.
2008 ZX14
ILUVNOS
posted April 30, 2010 09:12 PM
i spent over $20,000 with muzzy about 6 years ago, (between 3 bikes) and my muzzy lock up for my 12 started leaking oil, i replaced the gasket twice, come to find out the spacer plate was machined wrong and was letting the oil leak out. i took it to a machine shop and had them fix it out of my own money and never tried to get a refund or anything, ran into rob muzzy at the indy dealer show and told him about it, but told him i fixed it so it wasnt a big deal, his response, not i'm sorry, not i'll make it up to you, but "that's not possible, we sale a ton of those kits and never had anyone tell me that happened " ......what a rude asshole ! i was a dealer, and a long time customer and he pretty much told me to suck it.........i would never sale, own, or reccomend anything that says muzzy on it !
INTIMIDA2OR
RED rider!
posted April 30, 2010 10:06 PM
That really bites man. But Muzzy isn't known for their customer service unfortunately.
*Lee*
0.34530806541443 seconds processing time
