BIKELAND > FORUMS > ZX-14.com > Thread: Chain slack? NEW TOPIC NEW POLL POST REPLY
gilberjj
Friend of Fast
posted April 22, 2010 04:33 PM
Chain slack?
What kind of slack should I have in my chain at about 7 inches over? Is the purpose of chain slack to make sure there is enough chain slack for when the swingarm is perfectly flat (parallel with the ground)?
LAB3
posted April 22, 2010 05:00 PM        Edited By: LAB3 on 23 Apr 2010 01:03
http://sidewindersprockets.com/how_to.html
http://sidewindersprockets.com/drivetools.html
68gts2
hobbies ( Beating you !!! )
posted April 23, 2010 04:08 PM
Thanks Loius,there's a lot of meat on both of those bones. Great stuff.
LAB3
posted April 23, 2010 04:45 PM
Did you look at the tool that aligns the sprockets?? Or the chains and extoic alloy steel sprockets in any size.
Louis
LeonidasZX14
posted April 24, 2010 06:01 AM
Gilbjj
Many people have different opinions on chain tension. I run my chain SUPER tight just simply due to the fact my bike squats 4 inches when I launch. The chain loses alot of tension when you are under power. One other reason I run it tight is that I feel it gets the power down to the wheel that much quicker. WIth a loose chain it seems to me that it only puts power down once all the slack is out. Take a look at some pictures of how much chain slack people have while under power it is almost disturbing. Loose chains fly off!!!!
09' ZX14
0.30719709396362 seconds processing time
