BIKELAND > FORUMS > ZX-14.com > Thread: Need help on degreeing cams and thinner head gasket NEW TOPIC NEW POLL POST REPLY
serius blk
posted April 15, 2010 06:55 AM
going through a test run with one of my old zx14 heads. I used a thinner head gasket but when i set the cams at there stock marks i had some contact. So i stop turning the motor by hand. I read were smokin said the cams werent at the 105/105 position when using the thinner head gasket. I have everything to degree the cams but cant turn the motor due to the valve piston contact. Any advice on whats the next move. I also put on the adjustable timing gears. That may be the problem.
posted April 15, 2010 06:59 AM
Move the cams till you can turn the motor ...You must be way off for the valves to hit the pistons !
zxbob
posted April 15, 2010 07:03 AM
+ 1
A thinner head gasket would not cause that !
Bob
posted April 15, 2010 07:24 AM
as per manual get #1 at TDC , get alignment marks on cams set up, then adjust.
I had to have help with mine as it would move everytime I tightened the cam adjusters and jump a tooth... that was with .050 head gasket (turbo).
Look at old gears to help with position, intake and exhaust should be closed with #1 TDC
NINJA12
posted April 15, 2010 12:04 PM
Do you have the plugs out?
johnbull
posted April 15, 2010 01:09 PM
+2
Your problem must be the adjustable pullies because I can tell you from experience that on the standard marks, even with 28 thou skimmed off the head and using the thin 18 thou gasket, the valves still arent anywhere near hitting the pistons.
Good luck and just take it a step at a time.
John Bul Racing. Malta.
0.21196508407593 seconds processing time
