BIKELAND > FORUMS > ZX-14.com > Thread: ZX-14 Fuel pump wire color & location NEW TOPIC NEW POLL POST REPLY
bykw2
posted April 12, 2010 12:29 PM
I am trying to install and anti-hijacking senor on my zx14 as part of the alarm system.
Does any one the location and color the wires which goes to the fuel pump? I need to break the positive wire and install a relay in-line so the alarm can kill the fuel pump if the alarm is activated.
1badzx12r
posted April 12, 2010 01:29 PM        Edited By: 1badzx12r on 12 Apr 2010 21:30
its one of the 2 plugs at the back of the tank by the cap vent hose .. i just don't remember which one i had to tie into it to run an evac pump
1badzx12r
posted April 12, 2010 01:35 PM        Edited By: 1badzx12r on 12 Apr 2010 21:36
its the 1 with the 3 wires and its the black with yellow strip
bykw2
posted April 12, 2010 08:23 PM
Do I have to remove the fuel tank to get to the plug that house the black wire with yellow strip?
speedgene
posted April 12, 2010 09:36 PM
No.
Seat off, back of tank, find the two wire connector. Wire with the black/yellow is ground. Use white/red which is hot to the relay. The three wire connector is for the gas gauge, ECU, etc.
E-tard
68gts2
hobbies ( Beating you !!! )
posted April 13, 2010 04:03 AM
1bad zx12 please explain what type of evac pump you are talking about.
1badzx12r
posted April 13, 2010 04:25 AM
No.
i went and look at the fuel pump itself . the 3 wire plug is hook to it on this pump .. the black and yellow stripe wire hooks to the blue wire inside to the pump . the red stripe wire hooks to the low fuel light .. and the black and white stripe hook to ground ..
1badzx12r
posted April 13, 2010 04:27 AM        Edited By: 1badzx12r on 13 Apr 2010 12:28
http://www.cycle-logicmotorsports.com/index.php?main_page=product_info&cPath=6&products_id=27&zenid=978d8e7a4eb3a5fab0642268ba3c34d6
he sells some better pumps now ..but when i purchased my turbo this is all there was
68gts2
posted April 13, 2010 08:30 AM
Thanks for the info,always looking for hp.
posted April 13, 2010 10:08 PM
that pump will not make more HP by itself.
0.22737503051758 seconds processing time
