BIKELAND > FORUMS > ZX-14.com > Thread: Ti-Winder dyno numbers NEW TOPIC NEW POLL POST REPLY
icarus
posted April 05, 2010 02:43 PM
I went to Brock's Friday to do some testing and here are the results:
193.38 Horsepower
112.50 Ft/Lbs Torque
Run conditions were as follows:
72.92 deg F
29.13 in-Hg
39% humidity
Correction factor: SAE 1.01
Bike set up on dyno was:
17 / 48 gearing, 30 psi in Power One tire
MR-11 fuel
5th gear, 67 1/2" WB w/ 150 link EK DR2 chain
Flies out, no air filter
Needless to say I was very pleased. The only change made was a 3% addition of fuel
to the 6.5 - 11k rpm range at 100% throttle.
Later...
8.820 @ 161.05
bluechris
hungry fool
posted April 05, 2010 03:12 PM
Real nice numbers. What did you have on before and what HP?
ride safe
  Ignore this member    Click here to visit bluechris's homepage.
icarus
posted April 05, 2010 03:16 PM
I had an Alien Head on before that made 182 HP.
The bike set up has changed from that dyno run.
I went from 16/46 to 17/48 and have 3 inches more wheelbase.
Later...
8.820 @ 161.05
posted April 05, 2010 03:53 PM
The tiwinder gained 11hp over the alienhead?! Wow...
INTIMIDA2OR
RED rider!
posted April 05, 2010 04:01 PM
That's freakin awesome!
'06 Passion Red ZX-14
*Lee*
zx14fan
posted April 05, 2010 04:05 PM
11 hp?? Do you really belive that?
INTIMIDA2OR
RED rider!
posted April 05, 2010 04:34 PM
Anything is possible with brocks.
Especially race systems.
*Lee*
LAB3
posted April 05, 2010 05:09 PM        Edited By: LAB3 on 6 Apr 2010 01:10
MR-11 on second Dyno #s 193 bet pump gas on Allen head.
icarus
posted April 05, 2010 05:43 PM
No. MR-11 was used on both dyno runs.
8.820 @ 161.05
icarus
posted April 05, 2010 05:50 PM        Edited By: icarus on 6 Apr 2010 01:53
Found my other dyno sheet.
86.77 deg F, 29.31 in-Hg, 47% humidity
Correction factor: STD 1.05
16/46, 30 psi Power One, 64 1/2 wb
Fourth gear
Max power 182.10
Torque 103.86
Later...
8.820 @ 161.05
posted April 05, 2010 05:55 PM        Edited By: Shane661 on 6 Apr 2010 01:58
Different dynos? I see STD correction factor on the AH.
I will have my TiWinder on the dyno very soon.
icarus
posted April 05, 2010 06:34 PM
Both done at Brock's
8.820 @ 161.05
Wheelie
Old Man
posted April 05, 2010 06:35 PM
did you use injector cleaner?
wee
thutch26
thutch26
posted April 06, 2010 12:09 AM
great i have the same pipe... ive had mine since last season but have just been running an m14 map. waiting on the motor to get back now to get some dyno time.... good news!!!
LAB3
posted April 06, 2010 02:01 AM
Shane Please pot your Dyno #s when you install your Ti-winder............. hard
to go for another 10 HP on a exhaust. How much HP is the MR-11 good for????
Louis
LeonidasZX14
posted April 06, 2010 03:09 AM
wee
Looks like he did Wee.
09' ZX14
SteddyTeddy
posted April 06, 2010 04:27 AM
I think that gearing change had a lot to do with the #'s on the second run. You just don't gain TQ like that from an exhaust alone.
68gts2
hobbies ( Beating you !!! )
posted April 06, 2010 05:53 AM
10hp. Sounds like the dyno operator was drinking the cool-ade.if it was coming from the stock cans sure, but from an alienhead it seem to good to be true. The ct is only worth 3 according to Smokin who's results I have complete faith in. Not being a pecker just doubtful. The torque increase I agree with Teddy on being a result of the gear change. I am now curious what Shane's results will show since he has a detailed history with his pipe addiction. Ha ha.
Swiftkart
posted April 06, 2010 09:57 AM
Some of the increase could be the Alien Head he has listed as 4th gear test and the Ti-winder as 5th gear test, I think one of the mag's tested a 14 in several gears and the hp was higher in each gear they tested if I remember correctly.
INTIMIDA2OR
RED rider!
posted April 06, 2010 10:02 AM
*Lee*
posted April 06, 2010 10:04 AM
When comparing dyno #'s you would want the same dyno, operator, correction factors, a/f, and overall gear ratio...for starters.
oilfieldtrash
Kawasaki enthusiast
posted April 06, 2010 10:13 AM
+1 on a Shane661 review
'07 white S.E. ZX-14 sold
icarus
posted April 06, 2010 02:22 PM
Interesting discussion. I did not use any injector cleaner during either dyno session.
It was essentially to fine tune the map to my bike and riding style.
As for the difference in the numbers, I will say this: the dyno was recalibrated about a
week ago by DynoJet and mine was the second bike run on the dyno since recalibration.
8.820 @ 161.05
LAB3
posted April 06, 2010 02:43 PM
You will see for "Real" at the track. You are going Good now at 149. 10 more should back half a little better.
0.24885606765747 seconds processing time
