BIKELAND > FORUMS > ZX-14.com > Thread: Msd shiftlight install NEW TOPIC NEW POLL POST REPLY
posted March 28, 2010 02:00 PM
I'm hooking up a msd shiftlight from Shane tomorrow, and does anyone know of which color the positive coil wire is? Does it matter Which one I hook it to? Any advice would be greatly appreciated!
SixSixoh6
posted March 28, 2010 02:07 PM        Edited By: SixSixoh6 on 28 Mar 2010 22:10
positive wire is reddish pinkish i believe. just so im clear its the positive wire that goes to the coils right?
JIC http://www.msdignition.com/instructions/Products/RPM_Timing_Controls/89631.pdf?terms=89631
posted March 29, 2010 02:17 PM
Anyone got any pics of where theirs is located?? I didn't have time to get to it today, maybe tomorrow or wed
posted March 29, 2010 02:18 PM
If I mounted it on top of the guages between the windshield, what would be a good way to stick it to the guages so I didn't drill holes in it?
CraigChrist
BAWLS
posted March 29, 2010 02:59 PM
velcro maybe? That is a low pressure area so it's not like it's going to be getting blown around.
60ft-------1.42
1/8th------5.97
mph-------119
posted March 30, 2010 07:52 PM
Anyone have any pics?
pazx14rider
posted March 31, 2010 02:32 PM
shift light
posted March 31, 2010 03:44 PM
Pazx how did you mount that? That's a good idea to have it mounted on the side so you can get to the buttons
pazx14rider
posted April 01, 2010 05:16 AM        Edited By: pazx14rider on 1 Apr 2010 13:17
I just drilled two holes in the ram air tube cover for the bracket then took a hot soldering iron and melted a hole for the cable and while it was still gooey i pushed the wire down through for a nice tight seal. I will say being its over to the left it is more difficult to see during the day. I race most friday nites so its not much of a problem for me. putting it where i did does give you nice access to the buttons as you said.
pazx14rider
posted April 01, 2010 05:22 AM
Just a note on the hookup to the coil...your gonna have to use the pickup that came with it and loop the coil wire through the tang on the end of it to pick up the signal and gets set up through the shift light as a 1 clynder operation. hope that helps Eclipse
posted April 01, 2010 10:41 AM
Thanks!!!!
0.28682804107666 seconds processing time
