SixSixoh6
posted March 23, 2010 07:11 PM
Gear indicator
So after finally getting my bike back together and working out off the bugs, I've noticed some things.
After the install of my Muzzys BonneVille box, I've noticed my numbers on my gear indicator don't match up anymore. This is what it shows.
1st gear- #1 on screen
2nd gear- #2 on screen
3rd gear- #3 on screen
4th gear- blinks a 4 then goes to #3 but IS in 4th gear
5th gear- #5 on screen
6th gear- shows a #5 on screen.
This happen to anyone using this? Or a speedohealer??
Newf14
2007 ZX1400
posted March 24, 2010 04:04 AM
Seems my speedohealer dose somethin similar with the highre gearing,I had it 16/41 first and it was ok now I am at 16/44 and there seems to be a lag sometimes and sometimes it takes a good while to go from one number to another. I try to kep the gear I am in in my head anyway.
Newf14
SLVR_BLT
Chicken Strips!
posted March 24, 2010 08:15 AM
My bike is totally stock but i do notice the gear indicator seems to have a slight 2 second delay before it shows the gear i moved into. Is this considered normal on this bike?
bruno nadeau
posted March 24, 2010 08:20 AM
quote: My bike is totally stock but i do notice the gear indicator seems to have a slight 2 second delay before it shows the gear i moved into. Is this considered normal on this bike?
my 06 was like that my 09 is OK.
bruno nadeau
posted March 24, 2010 11:39 AM
My 06 has a couple second hesitation sometimes, but always went to the correct Gera. It was 16/43
Flame On
Fuel Air & Spark
posted March 24, 2010 12:16 PM
Same here slight hesitation but never a false gear.
77 RD 400
80 GS1000 GT
06 ZX14
SixSixoh6
posted March 24, 2010 02:59 PM
Yeah I'm getting the false gearing. Ill be in 6th gear and it will show a 5. I'm the same gearing as you eklipse
Superman T
posted March 24, 2010 03:06 PM
quote: Yeah I'm getting the false gearing. Ill be in 6th gear and it will show a 5. I'm the same gearing as you eklipse
Same here, I have my Healer set at -14.9%.
Ekilpse, do you have a Healer installed and what is your setting for proper speed/gear? My speedo seems to be dead on!
NinjaNick
'08 ZX14 (Blue)
posted March 24, 2010 03:42 PM
I have my healer set at -12.9% and gearing indicator is working like stock.
SLVR_BLT
Chicken Strips!
posted March 24, 2010 03:50 PM
Do these sensors work of rate of speed or how is that possible?
SixSixoh6
posted March 24, 2010 08:23 PM
You guys all got speedohealers, I got the muzzys bonneville box.
