BIKELAND > FORUMS > ZX-14.com > Thread: new m14 makes popping when let off the gas NEW TOPIC NEW POLL POST REPLY
j-bird09
09 se
posted March 21, 2010 01:55 PM
took for the first ride today when i let off the gas at about 3 grand it makes a pop through the exhaust what is this
09se flies out m14 bmc street pcv jeffo map 16t
posted March 21, 2010 01:56 PM        Edited By: Shane661 on 21 Mar 2010 22:02
Normal. It has to do with the way the ecu cuts/enables the fuel at around 3k rpm. SmokinZX14 could tell you more.
LeonidasZX14
posted March 21, 2010 01:57 PM
Did you plug off the air box in the bottom where the hose goes in?
09' ZX14
j-bird09
09 se
posted March 21, 2010 02:14 PM
no i didnt should i
Cutback
posted March 21, 2010 02:23 PM
Yes!
old enough to know better!
Bently
2012 14r In Blue and no Mods!
That will help but mine still popped if I let off the gas just at the right rpms
LeonidasZX14
posted March 21, 2010 03:20 PM
Yes, pull the 3/4 inch hose off of the bottom of the air box and plug it with the supplied plug. If it did not come with a plug buy the Muzzys pair block of kit which eliminates the smog system all together and it comes with a billet airbox plug. Mine still has a small pop but nothing like what I have heard on others.
09' ZX14
posted March 21, 2010 04:48 PM
+1
j-bird09
09 se
posted March 21, 2010 06:39 PM
ok do you plug off both the air box and the hose
j-bird09
09 se
posted March 21, 2010 06:43 PM
also when i put the pcv on will this help or eliminate it all together
posted March 21, 2010 06:48 PM
Yes plug both ...
posted March 21, 2010 06:55 PM
No .. It will allways pop on decell right about 3000 RPMs ... When you decell the fuel turns off , when the motor hit 3000 RPM the ECU fuel turns back on ....POP.... Ivans make a TRE that fixes the problem but your bike will not run right with it .. Just pull the clutch in before you hit 3000 and it will not pop ....
j-bird09
09 se
posted March 21, 2010 07:01 PM
ok thanks guys this is a great forum
LLcooljebb
Upgrade I Must
posted March 21, 2010 07:12 PM
the pop doesn't bother me...i like!
"no time to be void or save up on life
you got to spend it all.."
SLVR_BLT
Chicken Strips!
posted March 21, 2010 09:13 PM
I dont have a pop but during my usual rev match downshifts i sometimes get a really loud bang, probably a backfire. Sounds almost like a shotgun.
Superman T
posted March 22, 2010 12:08 AM
Pop = bang, one in the same...
LAB3
posted March 22, 2010 06:00 AM
TRE
gilberjj
Friend of Fast
posted March 22, 2010 06:04 AM
I just embrace fireballs that are expelled out of my exhaust.
knydecker
Uber-BigPimpin
posted March 22, 2010 06:22 AM
First didnt like the POP but now, liken it!
This was dictated... but not read!
bluechris
hungry fool
posted March 22, 2010 06:51 AM
A good POP gets the cagers attention.
ride safe
  Ignore this member    Click here to visit bluechris's homepage.
CraigChrist
BAWLS
posted March 22, 2010 01:34 PM
Especially at night. Nothing like releasing a 2.5 ft fireball into the air right next to a cage's drivers side window.
60ft-------1.42
1/8th------5.97
mph-------119
j-bird09
09 se
posted March 22, 2010 02:22 PM
by putting on the pcv and the map from muzzy will there be a noticable difference its seems rich still with it not installed
SLVR_BLT
Chicken Strips!
posted March 22, 2010 06:32 PM
You have a full exhaust with no fuel management or compensator? Or is it just a slip on?
j-bird09
09 se
posted March 22, 2010 06:38 PM
full system yes and bmc street no fuel management yet will be getting pcv
SLVR_BLT
Chicken Strips!
posted March 22, 2010 06:56 PM
oh, I bet that thing is running pretty lean.
0.233717918396 seconds processing time
