BIKELAND > FORUMS > ZX-14.com > Thread: 07 ZX14 Power Commander mounting NEW TOPIC NEW POLL POST REPLY
jrp0629
posted March 17, 2010 12:53 PM
Were is the best spot to mount a power commander on a 2007 ZX14?
Douglas Home
posted March 17, 2010 01:08 PM
Under the seat if your going to be changing maps alot. Tedious job to instal there.
Left ram air tube is easy.
Run a good earth to the battery as lots have earthing problems.
Doug Mackay Australia
posted March 18, 2010 06:50 AM
left ram tube is the easiest place. even if you have to access it frequently you just open the left cover 3 screws. I have the dynojet lcd so i can change maps anytime with no pc.
SixSixoh6
posted March 19, 2010 04:29 AM
def the ram air tube
SLVR_BLT
Chicken Strips!
posted March 19, 2010 09:51 AM
Mine is just above the coolant tank
gilberjj
Friend of Fast
posted March 19, 2010 09:56 AM
under the seat. I've done both and under the seat is best. You can ground it directly to the battery without lengthening the ground wire.
Quarter Pounder
with Cheese
posted March 19, 2010 12:16 PM
Mine was under the left side intake cover, but I moved it to fit under the seat. MUCH easier access to it now. Plan on an afternoon to do it and take your time to route all your wiring properly.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
dcjens
Wet side of Washington
posted March 19, 2010 07:04 PM
+1
Black 06
posted March 19, 2010 07:24 PM
+3 on under the seat! I wish I would have taken pics when I ran the wires... If I remember correctly there's only one way to run it. It's worth the time!
zx14r09se
posted March 20, 2010 02:50 AM
under the seat is the best and with the autotune its eZ to run the wire but under the ram air tube is a good place it would be nice to have a waterproof usb connecter to mount on the plastic of the bike for ez pluging
live to ride...but only on a 14
  Ignore this member    Click here to visit zx14r09se's homepage.
Newf14
2007 ZX1400
posted March 20, 2010 03:23 AM
I had mine on the ram air tube but moved it under the seat along with the speedohealer.+4 on the under seat, take the time to put it under the seat.
Newf14
Compton
posted March 20, 2010 11:19 AM
Leave it up front and run a usb cable to the rear.
b.w.
zxbob
posted March 20, 2010 07:40 PM
+ 1
Bob
68gts2
hobbies ( Beating you !!! )
posted March 22, 2010 07:55 AM
Damn Compton that a great idea! Do you have a cover on the open end of your usb?
northernkaw
posted April 03, 2010 12:25 PM
buy a speed cell battery or one off lyle and mount it in where you battery is.the wiring runs over top the motor and if you take the battery cover and cut the top off it you can pull the cover off with removing anything else. easy fit and you have removed over 10lbs of weight.
TampaGunSlinger
posted April 04, 2010 08:36 AM
here is where i put it
0.33652901649475 seconds processing time
